#51
Re: Touch Pro vs Touch Pro2: Should You Upgrade
“ Originally Posted by VenumX ”So here is my (VenumX's) take on the TP vs TP2 debate - Sorta a TP2 Review
GENERAL OVERVIEW/SCREEN/TILT So i got my TP2 in today and after messing with it for about an hour my recommendation is, if you've got the money buy it cause the screen looks amazing on this device, also the tilt is really convenient for sprint navigation on the road, especially if you have on of those sticky mats for your dashboard...SprintTV also looks really sexy on that screen, makes me actually wanna use my phone for media again... TF3D2 i was kind of disappointed that HTC just went with a gray background on the TF3D2, I really think they should have made it customizable for all tabs :/ The TF3D2 is what we would have expected tho very nicely laid out - the same as what you're used to on your TP just bigger KEYBOARD Ill start off by saying the keyboard is much larger on the TP2, not only because of the size of the phone itself, but also because the majority of the keys now have alternate functions as well; if you notice on the old TP this was not the case, the majority of the buttons had just one funtion (usually a letter). Also I don't like that HTC removed the tab button from the keyboard but they were smart about the comma on the keyboard, normally you have to press fn + period to get a comma instead they moved the comma to the left side of the spacebar and made it a primary key so that you dont have to push FN. They also removed the CTRL button which i've never really used before anyway and im not sure if it even had a use... Like i said a lot of the buttons have been merged with other buttons, no longer are dash and equals primary buttons they are the secondary functions of O and I, respectively. Overall the keyboard design on the TP2 has been very nice to type on and is spaced out a lot better; however they did sacrifice a keystroke for the user to get it this way. HTC START MENU Another big difference is the start menu on the new TP2, I like the setup they have its almost like the Motorola Q9 if you guys can remember that far back. When you push the start button it brings up a list of applications that you may find more useful or you may use on a daily basis, I find this as a VERY cool feature only because it is completely customizable which means for those people that used to find organizing icons on their start menu an annoying task, it has now been made easy for you. They give you 30 "favorite" slots on the initial start menu but if something you need is not on your start menu, you can press the "All Programs" button and get all of your programs...almost self explanatory! They do lock the Home, People, Calendar and Settings on that main menu, I'm not sure if that is unlockable or not yet...Overall makes things very easy to use and customize, THANKS HTC <3 CASE NO CASE....WTF HTC?!!@#?/ My TP1 came with one MEMORY CARD NO MEMORY CARD EITHER?! WHAT ARE YOU DOING TO ME HTC?!??!?!!? ZOOM BAR So because HTC TP2 - Mostly (if not all) WM's fault - does not have capacitive touchscreen the TP2 fails to have an onscreen zoom feature...so what does HTC decide to use for an alternative a zoom bar right below the screen. This is an awesome idea because anyone that has tried to do the circle around what they want to zoom in on has accidently rotated the pictures on the old versions of HTC Album. Now no mistakes can be made, the zoom bar is the zoom bar there is nothing else it will do, this means no more accidental rotation!! "But VenumX how do I rotate the picture on the fly then?!" - now why would you wanna do a silly thing like that..or at least thats what HTC seems to think, there is no way - that i have found - to rotate the images in the HTC album so you will need a 3rd party app for that...sorry.. MEMORY CONSUMPTION Since I've started this review the memory consumption has gone from 50% to 67% which tells me there is some kind of memory leak. I suspect that I just need to hard reset, I should have done this before I even used it so it's partially my fault and I was being greedy and wanted instant gratification 3.5MM HEADPHONE JACK So the jack is really nice to have seperate from the charger but why did you put it that close to the charger port, what if i need more space!! Put the headphone jack at the top of the phone!! that way if i need audio on the bottom (charger dock ) i can just use that port but if i need audio on the top if that jack was up there i would be able to plug it in and sit it up right side up >.< CMON think about design at least a little bit HTC I cant talk about the battery yet cause I haven't completely abused the phone yet :P but i suppose this is where I'm supposed to give my grand conclusion that changes your mind forever on getting the TP2. sorry to disappoint but I am non-conclusive on this...if you have the money GET THE DEVICE NOW WHAT ARE YOU DOING READING THIS?!?! if you are hard on money and this device is supposed to last you more than a year; wait for the new WM device and pass this one... |
#52
ok moved post to its own thread
#53
hahahha so you digigng it still buddy?
#54
yeah its real nice, they told me it would be 275$ after everything but i got a charge for 369.99 on my bill...so i gotta shoot em an email about that if they dont bring it down imma wait till 29 days then return it cause i really shouldnt be spending another $100 on a phone :/ and by then i will have bought the Hero from you, unless you need more than 2 or 3 days with the hero
#55
“ Originally Posted by VenumX ”yeah its real nice, they told me it would be 275$ after everything but i got a charge for 369.99 on my bill...so i gotta shoot em an email about that if they dont bring it down imma wait till 29 days then return it cause i really shouldnt be spending another $100 on a phone :/ and by then i will have bought the Hero from you, unless you need more than 2 or 3 days with the hero
#56
haha nice, ill take it off your hands at that point im not sure where im gonna get with the price n the TP2 so hopefully ill be able to keep both...if not...i save money and my rebate status gets reset :P
#57
the phone is hot... I didn't a flash on it tho for pics so I dont know how that is going to work but not really trippin about that. I just cant use the flashlight anymore like on TP1 but that is cool. I just got it yesterday so I'm still playing around with it. Hopefully some nice things come out for it.
#58
“ Originally Posted by dawishmaker ”the phone is hot... I didn't a flash on it tho for pics so I dont know how that is going to work but not really trippin about that. I just cant use the flashlight anymore like on TP1 but that is cool. I just got it yesterday so I'm still playing around with it. Hopefully some nice things come out for it.
#59
#60
“ Originally Posted by blackdiamond017 ”Can someone fill me in on why the TP1 flashlight is soo great? Everyone and their mama seems to have used it. BTW the TP2 ROCKS!
the flashlight was nice one for the thing it was which was flash for your pictures in dark areas and you coud than press and hold and have it stayed on for changing a tire in the dark, finding your way in the dark, etc. |
#61
Yea yea yea I know what I said earlier about waiting til the other TP comes out, but considering that I am in my (30 day grace period) guess what I am going to do? Yep, you got it I am going to go and get my TP2 tomorrow as soon as my feet hit the floor. Thanks to my friend giving me so much input on the phone about it, I guess it is time for me to go get the TP2. And considering that the TP3 is more like the diamond which I don't like I am going to go ahead and get this one. I will get back at you all when I get my new device and tell you what I think. Uhummmmm, I would also like to say that when I get this phone I am going to miss my GSS Rom, (boooo hoooooo) cause that rom is the shhhhhhhhhhhhhhhhhhhh, shut yo mouth, lol. So I guess what I am trying to say is that I am going to have to get used to the stock rom until i can get the titanuim rom again on the TP2. I have a digital camera with a flash so if I have to take a picture in the dark I guess I can use that. Wish me luck all. Peace.
--------- New Post Merged on 27/9/2009 at 0106 -------- “ Originally Posted by D/\SH ”the flashlight was nice one for the thing it was which was flash for your pictures in dark areas and you coud than press and hold and have it stayed on for changing a tire in the dark, finding your way in the dark, etc.
--------- New Post Merged on 27/9/2009 at 0550 -------- Ok so here is the deal, instead of me going to the sprint store (basically cause I want to be lazy today) I am just going to call in and do it that way. So I will get it sometime this week. Not in a rush, it's not like the phone is going to go anywhere. This way it will give me time to get my TP back to stock rom. |
#62
“ Originally Posted by mzlady26 ”Yea yea yea I know what I said earlier about waiting til the other TP comes out, but considering that I am in my (30 day grace period) guess what I am going to do? Yep, you got it I am going to go and get my TP2 tomorrow as soon as my feet hit the floor. Thanks to my friend giving me so much input on the phone about it, I guess it is time for me to go get the TP2. And considering that the TP3 is more like the diamond which I don't like I am going to go ahead and get this one. I will get back at you all when I get my new device and tell you what I think. Uhummmmm, I would also like to say that when I get this phone I am going to miss my GSS Rom, (boooo hoooooo) cause that rom is the shhhhhhhhhhhhhhhhhhhh, shut yo mouth, lol. So I guess what I am trying to say is that I am going to have to get used to the stock rom until i can get the titanuim rom again on the TP2. I have a digital camera with a flash so if I have to take a picture in the dark I guess I can use that. Wish me luck all. Peace.
--------- New Post Merged on 27/9/2009 at 0106 -------- Yes the light was better than some flash lights if you ask me, plus it was bright as all outdoors. --------- New Post Merged on 27/9/2009 at 0550 -------- Ok so here is the deal, instead of me going to the sprint store (basically cause I want to be lazy today) I am just going to call in and do it that way. So I will get it sometime this week. Not in a rush, it's not like the phone is going to go anywhere. This way it will give me time to get my TP back to stock rom. |
#63
nice review venum...u are a lucky man though with the phones and getting them.......
#64
Ok so check this out. I went to the sprint store to return my phone (cause of the 30 days) and they told me no cause i was past my 30 days, even after customer service told me I could. So I go to the store to see if they will honor what was noted n my account H e doulble hockey sticks no. So idk I am PISSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSSSSSSSSSSSSSSSSS*& off and there is nothing they will do about it.
#65
tp2 is looking really nice could use the xtra finger space on the screen maybe ill stop pressing multiple icons with the tp2----i am sad that the flash is gone but, the other features still makes the phone very wanted
#66
Re Touch Pro vs Touch Pro2 Should You Upgrade
I read a few people were lucky enough to get these activated on Boost. I've got a Mogul to play around with, but once some sweet ROMS come out for the TP2, I may have to trade up to this beauty and sell the Mogul.
#67
Picked my TP2 up at a local Sprint store yesterday. $200 out the door after a $400 two year ensemble discount on our corporate account. First of all that's a heck of a lot more discount than I expected and am not sure how it worked out that way, but I sure as he!! wasn't about to open my mouth and question it.
The phone is AWESOME. I loved my TP, but this thing made me have zero buyers remorse from the get go.
And now the cons
All I can say is overall I am way impressed with this new phone. It definitely has met every expectation I have developed over the last month while I waited for it. I am sure I will be even more impressed once the new HSPL is out and I can get back to WM 6.5 and the kick a$$ ROM's that I have become accustomed to. |
#68
i defenetly upgrading my touch pro has been acting wierd... i am going to get the touch pro 2
#69
I've been pondering the TP2, but with the dragon & others coming right around the bend AND my TP is now working flawlessly, I think I'll wait.
#70
I would just to keep up with the jones and get the new software/hardware.
#71
That's part of why I went from the Mogul to the Touch Pro. I really didn't NEED or even WANT a new phone, but when I found out there was something BETTER than my Mogul, I just had to keep up.
I use my phone for work every day and have modded it so that it's exactly what I need. It's not been the "top of the line" phone for a while, now, but it gets the job done & I'm hard pressed to believe that ANY phone would actually fulfill my personal needs any better. Plus, the prospect of installing all my apps, re-learning a new device, and the potential for malfunctions just has me sitting back & thinking I'll wait. But, I'd be a bold faced liar if I said there's a big part of me that isn't aching for a TP2, Droid, or... *drool* one of the upcoming Snapdragon powered devices. They give me goosebumps. |
#72
“ Originally Posted by roopull ”That's part of why I went from the Mogul to the Touch Pro. I really didn't NEED or even WANT a new phone, but when I found out there was something BETTER than my Mogul, I just had to keep up.
#73
Re: Re Touch Pro vs Touch Pro2 Should You Upgrade
“ Originally Posted by GokuSS3 ”That is what makes modding truely fun is having a new challenge something else to learn. Installing what you want is easy even if you flashing all the time. Just have to set it up the right way. Heck with my Pro I could flash and have all my app back on it like 30 mins. An i probably flash at least once a week if not more lol....
#74
Sprint gave me the tp2 4 free due to the keyboard issue on tp1 sprint said it was costin to much to keep replacin them... so if you have a sprint tp n want the tp2.. n your having keyboard issues i suggest you get it while the gettn is good!
#75
“ Originally Posted by Bluedakid ”Sprint gave me the tp2 4 free due to the keyboard issue.. sprint said it was costin to much to keep replacein them... so you you have a sprint tp n want the tp2.. n your have keyboard i suggest you get it while the gettn is good!
but none the less congrats on getting a touch pro 2 ! |
#76
Re Re Touch Pro vs Touch Pro2 Should You Upgrade
Maybe after the Christmas rush at UPS, I'll be more tempted to look at a better phone. Til then, I want something that I can operate with my eyes closed and without thinking! LOL! |
Tags |
pro, pro2, touch, upgrade |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Sprint replacing Touch Pro with Touch Pro2 | jr5416 | Random Community Topics | 316 | 01-08-2010 06:05 PM |
Do Touch Pro cabs work on Touch Pro2 | ActionPlyr | HTC Touch Pro 2 | 7 | 01-07-2010 08:49 PM |
Possible to trade-in touch pro for touch pro2 | ActionPlyr | Random Community Topics | 10 | 05-30-2009 03:58 AM |
[NEWS] HTC Touch Pro2 is awesome in ways the Touch Pro never could be | CYBER WEESJE | Random Community Topics | 22 | 02-21-2009 12:00 PM |
Layout Options | Width:
Fixed
Contact Us -
SPJ Bulletin -
Archive -
Privacy Statement -
Terms of Service -
Top
