Notices
UPDATED 1-08-2009 Dette Diamond Edition v24 Beta 1 RELEASED
Windows Mobile - COOKED ROM RELEASES
Post New ThreadReply
Thread Tools Search this Thread
  #101
Old 12-04-2008, 12:40 PM
mrpants20's Avatar
mrpants20 mrpants20 is offline
Member
Mobile Model: Touch & Touch PRO
Mobile Carrier: The Now Network
Mobile OS: 6.5
Uploads: 0
View mrpants20's Profile   Edit Options Edit Profile Picture View mrpants20's Photo Album Add mrpants20's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
Re: Dette 2D v23 Diamond Edition UPDATED 11-3-2008 (Vogue Only)
“ Originally Posted by Ketil View Post
Ok, this says (Vogue Only) in the title, so I assume this is a Vogue ROM with the Diamond look. I downloaded and started to flash 2.3, but the updater shows a Touch Diamond.
Am I missing something? Is this for the Vogue or not?
Yes this is for the Vogue, I have flashed this to my Vogue. It just shows the Diamond picture in the Rom Update Utility program for some reason....
The Following 2 Users Say Thank You to mrpants20 For This Useful Post:
  #102
Old 12-04-2008, 12:46 PM
Ketil's Avatar
Ketil Ketil is offline
Member
Mobile Model: HTC PPC6900
Mobile Carrier: Alltel
Uploads: 0
View Ketil's Profile   Edit Options Edit Profile Picture View Ketil's Photo Album Add Ketil's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
Thanks. I just wanted to make sure I didn't miss something somewhere and screw something up.
--------- New Post Merged on 4/12/2008 at 0223 --------
Awesome ROM!!! I'm a sucker for black.
The Following User Says Thank You to Ketil For This Useful Post:
  #103
Old 12-04-2008, 01:31 PM
dette's Avatar
dette dette is offline   Thread Starter
Member
Mobile Model: Touch Pro, Vogue
Mobile Carrier: Sprint
Mobile OS: 6.1
Uploads: 0
View dette's Profile   Edit Options Edit Profile Picture View dette's Photo Album Add dette's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
Nope your good! Its the Diamond RUU I believe
The Following User Says Thank You to dette For This Useful Post:
  #104
Old 12-05-2008, 04:02 PM
mrpants20's Avatar
Member
Mobile OS: 6.5
Uploads: 0
I switched from my Mogul to my Touch bc I like this ROM. Now that I have been using it for a day or so I've noticed a few things...
“ Originally Posted by dette View Post
THANKS! Thank you for the info! What happens for me is YouTube works fine until I run Live Search.. Then it F's up.. Something to do with Windows live and Live Search.. Thats weird
I could not open the YT app at all even off of fresh flash having never opened anything else.... Tried uninstalling Windows Live and still didn't work
When I answer the phone there is still like a 5 second delay before it actually answers. I didn't know if this was the same bug you knew about or if it was a different issue
Also when I receive a new text and the New Text Message window comes up (only from sleep mode) the soft keys like "Menu" (which brings up delete, reply, save, dismiss) freezes and I have to wait for the window to go away on its own before I can do any function on the phone. Same thing happens with the alarm when it goes off and the phone is in sleep mode, I can not hit snooze or anything
  #105
Old 12-05-2008, 04:44 PM
dette's Avatar
Member
Mobile OS: 6.1
Uploads: 0
“ Originally Posted by mrpants20 View Post
my advice would be hard reset.. even though you just flashed and I know it sounds like it wouldnt do much but just do a hard reset.. a lot of times it clears stuff up
The Following 2 Users Say Thank You to dette For This Useful Post:
  #106
Old 12-05-2008, 06:44 PM
iamdasht19's Avatar
iamdasht19 iamdasht19 is offline
Member
Mobile Model: TP, TP2, soon Hero
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
View iamdasht19's Profile   Edit Options Edit Profile Picture View iamdasht19's Photo Album Add iamdasht19's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
for sure and if you havent after flashing this rom also take the battery out for a minute and reinsert... this allows the pagepull to be refreshed.
The Following User Says Thank You to iamdasht19 For This Useful Post:
  #107
Old 12-05-2008, 07:38 PM
metallized's Avatar
metallized metallized is offline
Member
Mobile Model: touch pro wm6.5
Mobile Carrier: sprint
Mobile OS: 6.5
Uploads: 0
View metallized's Profile   Edit Options Edit Profile Picture View metallized's Photo Album Add metallized's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
anybody have any idea why the slide to answer is not working properly.... i mean it works but not that good... most of the times when i slide it it does not answer at all.... i tried calling myself from a land line and even after sliding i could still hear my call tone on the land line fone so it was not answering..... it has not been working good since the first time i flashed this rom.... any idea ?? should i hard reset ??
  #108
Old 12-05-2008, 07:45 PM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
“ Originally Posted by metallized View Post
you could try that, but are you sure that you are sliding it all the way?
  #109
Old 12-05-2008, 07:56 PM
metallized's Avatar
Member
Mobile OS: 6.5
Uploads: 0
well yah..... but ur rite, if i really concentrate and slide it all the way then it works fine, but if i just do it like normally i would it will not answer and more over it stucks rite there and only the end key works... now i've started using the send key to answer... u know that slide to lock theme, s2u2, i wish it'd work atleast like that.... its not working properly..... everything else is gr8 tho.....
  #110
Old 12-05-2008, 09:01 PM
auien's Avatar
auien auien is offline
Member
Mobile Model: Htc touch
Mobile OS: 6.1
Uploads: 0
View auien's Profile   Edit Options Edit Profile Picture View auien's Photo Album Add auien's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
I have tried to update the rom about ten times and i keep getting the same error[262] any ideas that might help am using the htc touch from sprint
  #111
Old 12-05-2008, 09:22 PM
1mrlcb's Avatar
1mrlcb 1mrlcb is offline
SPJ FREAKSTER!
Mobile Model: PRO&DIAMOND!!
Mobile Carrier: Rev a speeeeeddddddd
Mobile OS: 6.1
Uploads: 0
View 1mrlcb's Profile   Edit Options Edit Profile Picture View 1mrlcb's Photo Album Add 1mrlcb's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
“ Originally Posted by auien View Post
Whats the error because i dont know them by the numbers?
  #112
Old 12-05-2008, 09:31 PM
1mrlcb's Avatar
SPJ FREAKSTER!
Mobile OS: 6.1
Uploads: 0
  #113
Old 12-05-2008, 11:01 PM
mrpants20's Avatar
Member
Mobile OS: 6.5
Uploads: 0
“ Originally Posted by D/\SH View Post
Thanks guys, I already did the battery thing.... I kinda figured a hard reset was in order, but I was just resisting so I wouldnt have to spend a half an hour reinstalling all my apps and finding the serials.... But I did hard reset and everything works like a charm!
Again, great work Dette!
  #114
Old 12-05-2008, 11:12 PM
auien's Avatar
Member
Mobile OS: 6.1
Uploads: 0
I Am new a this stuff can someone tell how do i install
  #115
Old 12-05-2008, 11:13 PM
1mrlcb's Avatar
SPJ FREAKSTER!
Mobile OS: 6.1
Uploads: 0
Please look in my sig at how to flash a rom
The Following User Says Thank You to 1mrlcb For This Useful Post:
  #116
Old 12-05-2008, 11:19 PM
auien's Avatar
Member
Mobile OS: 6.1
Uploads: 0
what do you me by sig ?
  #117
Old 12-05-2008, 11:27 PM
1mrlcb's Avatar
SPJ FREAKSTER!
Mobile OS: 6.1
Uploads: 0
The thing under my post but just go to this link https://www.smartphonejunkie.org/sho...=FLASHING+ROMS
  #118
Old 12-05-2008, 11:37 PM
auien's Avatar
Member
Mobile OS: 6.1
Uploads: 0
when i click on a link under the touch sec. it says i don't have permission to view it
  #119
Old 12-05-2008, 11:40 PM
1mrlcb's Avatar
SPJ FREAKSTER!
Mobile OS: 6.1
Uploads: 0
Well you need to join members software and that can be found in my sig to
  #120
Old 12-05-2008, 11:44 PM
puertoblack2003's Avatar
puertoblack2003 puertoblack2003 is offline
OG Member
Mobile Model: Pixel 7 Pro
Mobile Carrier: Metro PCS
Mobile OS: Android
Country:
Uploads: 152
View puertoblack2003's Profile   Edit Options Edit Profile Picture View puertoblack2003's Photo Album Add puertoblack2003's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
i'm going to help you a bit.Apparently when you registered and was redirected to the informational introduction post before moving to other area of the forum.You didn't take time to read, otherwise you would have known what to do.So i fixed that for ya. You've been redirected to that post and i suggest you take your time and follow it...so you know what to do.
I want this post clean for real support question about the rom.
The Following 4 Users Say Thank You to puertoblack2003 For This Useful Post:
  #121
Old 12-06-2008, 01:45 AM
dette's Avatar
Member
Mobile OS: 6.1
Uploads: 0
“ Originally Posted by puertoblack2003 View Post
Thanks...
I also wanna keep this for questions and comments(and occasional rambling) about the ROM itself =]. you know how it goes
  #122
Old 12-06-2008, 12:35 PM
mrpants20's Avatar
Member
Mobile OS: 6.5
Uploads: 0
Is it possible I have an app that is conflicting with this ROM? After a hard reset and installed about half of my apps back its doing the same thing as before. After I installed the first handful of apps I kept testing it by calling and sending myself texts from another phone after every install and everything was still working. So I stopped testing and just finished the rest of the apps. I am going to hard reset again and test after every install, maybe I'll find something...
I'll report back if I find anything....
  #123
Old 12-06-2008, 12:39 PM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
its prolly two apps conflicting with eachother and not the rom...... what apps were you running when it worked fine and what did you add after that point that made it do whatever since you didnt share that with us
  #124
Old 12-06-2008, 02:41 PM
mrpants20's Avatar
Member
Mobile OS: 6.5
Uploads: 0
I'm not running anything different than I had in my Mogul.... I just tried installing everything again and it worked every step of the way until I opened the Windows folder to place a sound file for alarm via active sync (i didn't put anything in or remove anything yet) but I don't know if that was a coincidence or if that actually did something...
Anyway, heres the apps I'm running:
DCD Spint carrier cab installed first then..
Skyfire
SPB Full Screen Keyboard (latest build)
SIP Change
Sling Player Mobile
Mobi TV (installed, not used)
Music ID
XM Mobile
NFL Mobile
Op Mon
Text twist
Sprite Backup
Pdanet
Dallas Cowboys M2D theme applied via M2dconfig
Gmail
Mail2web Free Direct Push
Like I said I had all of that installed and ran at least once, soft reset after all complete and it still worked properly... Then I went to place a sound file in windows, never actually did bc I got a call (and it answered properly). Then the next call 15 min later did not answer properly.... Frustrating
  #125
Old 12-06-2008, 03:18 PM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
Skyfire
SIP Change
Sling Player Mobile
Music ID
XM Mobile
NFL Mobile
Op Mon
Text twist
Sprite Backup
Pdanet
Gmail
what did you install after that phone call?
  #126
Old 12-06-2008, 03:40 PM
mrpants20's Avatar
Member
Mobile OS: 6.5
Uploads: 0
Nothing, thats what I don't get. Everything installs and works fine, the first call answers just fine, and then I did nothing else to it and the next call started the issues again.
  #127
Old 12-06-2008, 04:30 PM
metallized's Avatar
Member
Mobile OS: 6.5
Uploads: 0
has anybody tried sprint mobile email on this rom ??? its not installing properly on mine... when i try to rum the cab file, it gives me a error saying "can not load resources(126,7e)" ... it does that few times and then stays on that installing screen but the progress bar does not change so i have to reset my fone.... i thought it was my fone so i did a hard reset this morning and now its giving me the same error again... so i don think its my fone... any idea guys ????
  #128
Old 12-06-2008, 05:14 PM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
i think sprint emai is done with and no one has it anymore..... or doe that start at the beginning of the year.... havetn looked into this recently.
  #129
Old 12-06-2008, 06:24 PM
mrpants20's Avatar
Member
Mobile OS: 6.5
Uploads: 0
After messing with this for HOURS.... I think I may have found out what was making it buggy. The newest version of SlingPlayer Mobile and the XM radio/Music ID/MobiTV combined cab install. After installing those (respectively) the bugs came back. After uninstalling soft reset, everything worked like it was supposed to.... I installed an old version of Slingplayer and the new standalone tactile version of Music ID and it seems to be working fine again.
The Following User Says Thank You to mrpants20 For This Useful Post:
  #130
Old 12-06-2008, 06:28 PM
metallized's Avatar
Member
Mobile OS: 6.5
Uploads: 0
i thought that sprint email account was gonna discontinue.... but im talking about the sprint mobile email program.... r they same thing ??? but i was using it until few days ago when i flashed my device with this rom... but may be ur rite dash ??? so can anyone suggest me if there is any other programs like sprint mobile email... to get emails from few different accounts ????
  #131
Old 12-06-2008, 08:03 PM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
had a feeling that it was an app that was conflicting with another one.... thanks for telling us what you found out and glad that you are back up and running :>
  #132
Old 12-07-2008, 01:59 AM
Ketil's Avatar
Member
Uploads: 0
I'm having a weird problem with this.
The first time I installed this, I was having a similar problem to mrpants delay in ringing. I had already set the slot index to 0 but it was still delaying answering. But otherwise, everything was working correctly.
So I decided to do another hard reset after yanking the battery again. (did that when I originally installed this rom)
After it rebooted and loaded everything it now answers calls correctly. But now, push mail isn't pushing. I set up mail2web and if I do a manual send/receive it works. If I go to the com setting in touchflo (next to last tab) and turn push off and turn it back on it immediately gets my mail. But then it won't push again until I turn push off and back on.
Any ideas?
  #133
Old 12-07-2008, 09:42 AM
Sahil01's Avatar
Sahil01 Sahil01 is offline
Member
Mobile Model: Touch 6900
Mobile OS: 6.1
Uploads: 0
View Sahil01's Profile   Edit Options Edit Profile Picture View Sahil01's Photo Album Add Sahil01's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
ok i am having problems with connecting to the internet using the phone.. before flash the new rom internet was working fine.. any idea whats going on.. i am paying sprint 15 dollars a month would rather donate it here for help...
  #134
Old 12-07-2008, 09:51 AM
1mrlcb's Avatar
SPJ FREAKSTER!
Mobile OS: 6.1
Uploads: 0
“ Originally Posted by Sahil01 View Post
Did you hard reset after your flash?
  #135
Old 12-07-2008, 12:05 PM
metallized's Avatar
Member
Mobile OS: 6.5
Uploads: 0
did u install the DCD cab thats on the top the first page here ??? if u haven't install that and u will be fine.......
The Following User Says Thank You to metallized For This Useful Post:
  #136
Old 12-07-2008, 09:00 PM
dette's Avatar
Member
Mobile OS: 6.1
Uploads: 0
install the DCD cab for your carrier
  #137
Old 12-07-2008, 10:50 PM
Ketil's Avatar
Member
Uploads: 0
Anyone else experience any problems with push mail on this rom? I've re-flashed a couple of times now and still can only push once after I turn push of and then back on. It will not push again until I repeat.
I'm thinking of flashing stock and then reflashing to this rom to see if it clears up. Just hate to go through all that if it's something that can be fixed easily.
  #138
Old 12-07-2008, 11:02 PM
metallized's Avatar
Member
Mobile OS: 6.5
Uploads: 0
same problem here with my hotmail.... but my yahoo works fine....
  #139
Old 12-08-2008, 10:15 AM
Ketil's Avatar
Member
Uploads: 0
I'm not talking about webmail.
Windows Mobile allows you to push mail to your phone much like the blackberry. I have been using mail2web as my exchange server since they are free. Instead of having the phone check mail periodically, I normally get my mail as it arrives via push.
But it's not working now. It will only work immediately after I turn push off and back on via the comm panel.
I love the look of this rom and the touchflo that's included. Way better than stock.
But since push mail is an essential for me, I'm gonna have to go back to kaos' rom I guess. It must just be something specific to my setup or maybe I'm the only one using push mail. I dunno.
***** Edit **** I just checked hotmail and see that they now offer push mail for mobile phones. Is this what you are using or are you having problems with the webmail? If with the push, then I am curious how many users of this rom are actually using push and how many are having problems making it work?
  #140
Old 12-08-2008, 01:25 PM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
i tested on a backup phone and my push email through mail2web worked fine on this rom.
  #141
Old 12-08-2008, 01:56 PM
Ketil's Avatar
Member
Uploads: 0
What's weird is it worked fine for me the first time I flashed to this rom. I did a hard reset because I was having same issue with delayed ringing as mrpants. After the hard reset was when I started having problems with push.
I'm flashing stock now. Once I verify push is working again, I'll reflash this rom and see what happens.
--------- New Post Merged on 8/12/2008 at 0323 --------
Push working on stock. Reflashing Dette 2D....
--------- New Post Merged on 8/12/2008 at 0437 --------
Back on Dette 2D and push mail is working.
--------- New Post Merged on 8/12/2008 at 0517 --------
And it's dead again.....
BUT, I think I've narrowed down the problem. This time I forgot to change my regional settings from English (Australia) to Englush (US) until after I had set up mail2web. I also like to change the device ID to something more personal. I did both of these after setting up and verifying working push.
I'm going to hard reset and change them one at a time to see which one breaks push.
--------- New Post Merged on 8/12/2008 at 0759 --------
Several hard resets and it still won't work. Reflashing stock again...
--------- New Post Merged on 8/12/2008 at 0740 --------
Actually, that was several hard resets and another reflash of Dette 2D and it still isn't working. Whatever it is, once broken it doesn't seem to be repairable until you go back to stock.
Stayed tuned.....
--------- New Post Merged on 8/12/2008 at 0808 --------
After much flashing and reflashing, it appears that changing the regional setting from English (Australia) to English (US) is the culprit. And once you change it to US, even hard resetting doesn't fix it.
The only way I have been able to get push back was to flash back to stock and then reflash Dette 2D.
D/\SH, since you tested this on an old phone, can you verify that your regional settings are English (Australia) by default and that push is working?
Then will you change your regional setting to English (US) and soft reset, then see if push still works for you or if it is broken?
  #142
Old 12-10-2008, 06:05 PM
dette's Avatar
Member
Mobile OS: 6.1
Uploads: 0
Stayed tuned.....
Gooooodness you posted a lot!
Here is how I and everyone else fixed the Push Email bug
“ Quote ”
[HKEY_LOCAL_MACHINE\Comm\ConnMgr\Planner\Settings]
"SuspendResume"=multi_sz: "#777"
(this would show "~GPRS!" by default delete that and replace it with "#777" as above)
  #143
Old 12-17-2008, 04:00 PM
youngmoney5's Avatar
youngmoney5 youngmoney5 is offline
Member
Mobile Model: HTC 6900
Mobile OS: 6.1
Uploads: 0
View youngmoney5's Profile   Edit Options Edit Profile Picture View youngmoney5's Photo Album Add youngmoney5's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
Re: Dette 2D v23 Diamond Edition UPDATED 1132008 (Vogue Only)
how do I go about installing this on my phone?
  #144
Old 12-17-2008, 04:11 PM
drdrewdown's Avatar
drdrewdown drdrewdown is offline
Member
Mobile Model: Touch Pro Chrome
Mobile OS: 6.5
Uploads: 0
View drdrewdown's Profile   Edit Options Edit Profile Picture View drdrewdown's Photo Album Add drdrewdown's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
“ Originally Posted by youngmoney5 View Post
before everyone yells at you there are links in dette's sig about it.. get at me on one of the chat clients in my profile if you wish. GL
The Following 2 Users Say Thank You to drdrewdown For This Useful Post:
  #145
Old 12-17-2008, 04:20 PM
Superman369's Avatar
Superman369 Superman369 is offline
Member
Mobile Model: Touch Prizo!!!
Mobile OS: 6.5
Uploads: 0
View Superman369's Profile   Edit Options Edit Profile Picture View Superman369's Photo Album Add Superman369's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
and read the noob guide and forum rules bro.....we got em there for just this reason
The Following User Says Thank You to Superman369 For This Useful Post:
  #146
Old 12-19-2008, 02:37 AM
dette's Avatar
Member
Mobile OS: 6.1
Uploads: 0
Hey guys....
Wow sorry about the absense from this thread! and the whole forum!
I had a little computer OS malfunction here!
I had to wipe my entire computer and start over basically.. I finally got it working though so it should be good and I can get on here more often now!
Long story short...
Getting a virus on XP(ended up formatting)
XP and Vista disc's WOULD NOT install for me! (piece of shit Windows!)
I had to finally format with a Mac DVD and then I installed Mac (again...)
And then XP STILL wouldnt install on the other partition
Finally I got Vista to install.. (By this time im pissed off)
Then my Dual boot F***ed up and Mac wouldnt work anymore! So I had to re install mac..
Finally my Dual boot of Vista and Mac works!
Since I just typed that out and it isnt relivent to this thread.. Heres the main thing
I will answer any questions I can tomorrow because its 2:30AM right now and I feel like Im dying.
See ya
  #147
Old 12-19-2008, 02:48 AM
iamdasht19's Avatar
Member
Mobile Carrier: SPJ
Mobile OS: 6.5
Uploads: 0
Hey guys....
Long story short...
See ya
glad that you got everything back and working right for ya again
  #148
Old 12-19-2008, 01:44 PM
dette's Avatar
Member
Mobile OS: 6.1
Uploads: 0
Thanks its nice to have it working again
  #149
Old 12-21-2008, 01:49 PM
metallized's Avatar
Member
Mobile OS: 6.5
Uploads: 0
i am having some problem with the S2U2 ( i guess)... wherever i get any call i slide the answer key and it freezes on me.... i can't answer at all... almost everytime i have to call them back coz it wont let me answer.... so i turned off everything on the S2U2 settings and i got the original htc's answer or ignore things... but its still doing the same even on the htc's options... is it because of the S2U2 ??? if yes then is there a way to completely take it off of my fone coz i did not see it under the remove programs options.....
  #150
Old 12-21-2008, 03:02 PM
TaylorSPJ's Avatar
TaylorSPJ TaylorSPJ is offline
Nickel Nickel NINE
Mobile Model: HTC DIAMOND
Mobile OS: 6.1
Uploads: 0
View TaylorSPJ's Profile   Edit Options Edit Profile Picture View TaylorSPJ's Photo Album Add TaylorSPJ's to Your Contacts Show Groups Edit Avatar Subscribed Threads Private Messages
did you soft reset after goin back to original htc answer ignore? if not try that and see if it helps...and possibly reinstall s2us then soft reset....if it has been doin this from the start of install it may have just been a corrupt install, if it started to do it after a period of time i'd check and see what you installed after s2u2, something can be conflicting w/ eachother.
The Following 3 Users Say Thank You to TaylorSPJ For This Useful Post:
Tags
beta, dette, diamond, edition, manila, released, touch, touchflo, updated, v24, vogue
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
[RELEASE] Inesoft Phone v50 beta 6 build [UPDATED MAY 4 2009] scott8813 WM And PPC Applications 3 06-14-2009 03:13 PM
[UPDATED 01/Oct] ThrottleLauncher 094k Beta released Mike20PR Mobile Programs 5 10-16-2008 11:05 PM
Layout Options | Width: Fixed
Contact Us - SPJ Bulletin - Archive - Privacy Statement - Terms of Service - Top
