Thread Tools | Search this Thread |
#201
Re: UPDATED 1-08-2009 Dette Diamond Edition v24 Beta 1 RELEASED
Hey bro, I believe it is called S2U2.
The Following User Says Thank You to lilkrazzie For This Useful Post: | ||
#202
no thats slide to unlock.....but nevermind i found it...
#203
@above - do you know what it was called then? thanks
Hey Dette, great rom and loving it. Had some questions though. I did not see flashbundle in the list of updates up to 2.3, thats what im running. Also I was wondering if there is a simliar program to HHC that will work on this rom and if that weather patch file will work with the weather program that you have. Another thing is there a way to turn off the sound when i am clicking on start menu? |
#204
its called opal phone canvas.... search for it u will find it.... i fould it on two threads... there is one where there is only one file of about 10 mbs...... there r few problems on that and there is another thread where there r like 5 or 6 files..... install all of them and "U WILL BE GOLDEN"
The Following User Says Thank You to metallized For This Useful Post: | ||
#205
“ Originally Posted by lilkrazzie ”@above - do you know what it was called then? thanks
Hey Dette, great rom and loving it. Had some questions though. I did not see flashbundle in the list of updates up to 2.3, thats what im running. Also I was wondering if there is a simliar program to HHC that will work on this rom and if that weather patch file will work with the weather program that you have. Another thing is there a way to turn off the sound when i am clicking on start menu? Flash works in Opera for a program like HHC for Manila just get M2DC (Manila 2D Customizer) Search XDA for the patched weather To turn off the sound for the menus go to: Settings>Personal>Sounds & Notifications>Events (warnings, system events) and uncheck that box |
The Following User Says Thank You to dette For This Useful Post: | ||
Tags |
beta, dette, diamond, edition, manila, released, touch, touchflo, updated, v24, vogue |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
[RELEASE] Inesoft Phone v50 beta 6 build [UPDATED MAY 4 2009] | scott8813 | WM And PPC Applications | 3 | 06-14-2009 03:13 PM |
[UPDATED 01/Oct] ThrottleLauncher 094k Beta released | Mike20PR | Mobile Programs | 5 | 10-16-2008 11:05 PM |
Layout Options | Width:
Fixed
Contact Us -
SPJ Bulletin -
Archive -
Privacy Statement -
Terms of Service -
Top
