Thread Tools | Search this Thread |
#251
Re: StarROM 20 (The New Beginning) WM 65 5221222
Use SomeguyMMS or read the thread Kaos started on "Sprint Picture Mail Fix". You have to start reading a searching a little better man.
The Following 5 Users Say Thank You to Superman369 For This Useful Post: | ||
#252
search for the arcsoft cab. this is what u want. if you read through this thread you'll find it. it's been talked about.
The Following 2 Users Say Thank You to only1penny For This Useful Post: | ||
#253
“ Originally Posted by D/\SH ”if you arent going to use touchflo 3d than go without it since it will save you a lot of hassle and space on your device.
But I can't seem to get those fixes right. There were two htcCalculator files, and one was the .exe. So I deleted the htcCalculator from the start menu & pasted the .exe file there, but now I have no calculator. What did I do wrong and how can I get the calculator back? |
The Following User Says Thank You to ebuzz For This Useful Post: | ||
#254
“ Originally Posted by ebuzz ”OK, reflashed and the Comm manager fixed worked fine. I think I'll keep this ROM for awhile. I did screw one thing up, however, I tried to do the calculator fix: "So you just go to Device/Windows and scroll until you see htcCalculator in there. After that hold down on it and copy. Navigate to Device/Windows/Start Menu/Programs and delete the HTC Calculator shortcut that is already there. Then just paste shortcut and if you want you can rename the shortcut to HTC Calculator instead of htcCalculator."
The Following 5 Users Say Thank You to parna1973 For This Useful Post: | ||
#255
I found it easier to just install a new HTC calculator and now it works from both the start menu and the mobile shell widget. (Not using the TF3D.)
The Following 5 Users Say Thank You to ebuzz For This Useful Post: | ||
#256
Re: StarROM 65 5221202 Touch Pro V13 (Rhodium clock patched to G-Alarm)
sweet m8..will donlod it later..thx
#257
question...thinking about flashing to this rom. is this for alltel? im guessing not because there was someone asking how to get mms to work. on my mogul whenever i had to try and get mms working by installing programs it never worked. so id like to get one for alltel that still had mms enabled without installing things.
#258
“ Originally Posted by m260gt ”question...thinking about flashing to this rom. is this for alltel? im guessing not because there was someone asking how to get mms to work. on my mogul whenever i had to try and get mms working by installing programs it never worked. so id like to get one for alltel that still had mms enabled without installing things.
The Following 3 Users Say Thank You to iamdasht19 For This Useful Post: | ||
#259
so im about to flash to this rom...im just looking around for the stock altel rom in case it doesnt work. i cant seem to find it on htc's website. i know it has to be there i just cant find it
#260
“ Originally Posted by m260gt ”so im about to flash to this rom...im just looking around for the stock altel rom in case it doesnt work. i cant seem to find it on htc's website. i know it has to be there i just cant find it
Codehttps://www.smartphonejunkie.org/showthread.php?t=178602 |
#261
wow im liked by dash? lol.i feel special. thanks dash. i didnt think youd have it on here since its a stock rom
#262
The Following 2 Users Say Thank You to iamdasht19 For This Useful Post: | ||
#263
flashing now. i guess ill let customizations run?
--------- New Post Merged on 26/6/2009 at 0221 -------- flashed to it. there was no mms. so i found the arcsoft cab on ppc geeks. installed that and still the mms wont work. the option is there but it wont let me start a new mms message...so idk if ill be staying on this rom. looks like a really clean rom though! --------- New Post Merged on 26/6/2009 at 0803 -------- is flashing the TP the same as the mogul? like do i have to pull out the battery and hard reset after flashing? |
The Following User Says Thank You to m260gt For This Useful Post: | ||
#264
“ Originally Posted by m260gt ”flashing now. i guess ill let customizations run?
#265
#266
pretty sure hes alltel
The Following User Says Thank You to VenumX For This Useful Post: | ||
#267
The titanium version seems to work fine, but I have been wanting to use the TF3D2 version and that version just won't let me use internet at all no matter what I do.
I have done 2 flashes and 4 hard resets and I've manually configured the internet with #777 and I've also installed the dcd sprint carrier. cab as well to no avail. I'm going to throw it out the window and go to another TF3D2 rom. I like 6.5 and all, but I like the built in calender for planning more. |
The Following 2 Users Say Thank You to nadcicle For This Useful Post: | ||
#268
yeah im with alltel. i tried using it today again but it still wont work right. the arcsoft doesnt work for mss. and the phone was freezing and acting very sluggish. so im back stock now. looked really clean and sleek tho. i wish it would have worked.
#269
you only tried one rom before going back to stock? there are many nice ones out there to try from.
#270
I tried doing the wmplayer paste in the start menu but I don't get the option to paste. How can I get that to work? Also my touch flo album viewer won't play videos. Would this two be related?
The Following User Says Thank You to 7thHTC For This Useful Post: | ||
#271
“ Originally Posted by D/\SH ”you only tried one rom before going back to stock? there are many nice ones out there to try from.
i cant find the arcsoft cab on this site, i found it on ppcgeeks and it was version 5_0_31_7. is there a newer one? it says it was made for an older version of windows. that may be my mms problem. |
The Following 3 Users Say Thank You to m260gt For This Useful Post: | ||
#272
this is what im using with no problem..
Codehttps://www.smartphonejunkie.org/showthread.php?t=181977&highlight=arcsoft |
The Following 7 Users Say Thank You to tlpalmer01 For This Useful Post: | ||
#273
I can't get the windows media player icon to paste in the start menu folder. I can copy the icon but it doesn't give me the option to paste it when I go to the start menu folder, and I can't do it if I plug the phone in via usb on the windows explorer. Anyone have that problem too?
#274
“ Originally Posted by 7thHTC ”I can't get the windows media player icon to paste in the start menu folder. I can copy the icon but it doesn't give me the option to paste it when I go to the start menu folder, and I can't do it if I plug the phone in via usb on the windows explorer. Anyone have that problem too?
The Following 6 Users Say Thank You to Superman369 For This Useful Post: | ||
#275
i did both wmplayer.exe and .lnk and still doesn't work. Still just have a dead link in the start menu. pictures and videos still says " source filter for this file could not be loaded " when i try to watch videos taken with the camera.
The Following 2 Users Say Thank You to 7thHTC For This Useful Post: | ||
#276
I was wondering if there is a way to delete an app that appears to be cooked into the ROM. I think I have a bad dotfred task manager. It seems that when I try to launch it a progress bar gets about half-way across the screen then freezes (it says "cancel"). I want to either delete it and install again or use a different task mgr. I cant seem to figure out how to delete it. If the remove programs won't work, can I just delete all references to it in the registry an in the windows folders using Total Cmdr or whatever?
#277
“ Originally Posted by ebuzz ”I was wondering if there is a way to delete an app that appears to be cooked into the ROM. I think I have a bad dotfred task manager. It seems that when I try to launch it a progress bar gets about half-way across the screen then freezes (it says "cancel"). I want to either delete it and install again or use a different task mgr. I cant seem to figure out how to delete it. If the remove programs won't work, can I just delete all references to it in the registry an in the windows folders using Total Cmdr or whatever?
The Following 3 Users Say Thank You to jr5416 For This Useful Post: | ||
#278
I tried that. I found a cab and reinstalled, but that didn't work.
#279
Cant uninstall a app already built into a rom , just will have to use a different task manager or flash another rom. I didn't have that problem with this rom. You pulled out the battery after flash and hard reset ?
The Following 4 Users Say Thank You to GokuSS3 For This Useful Post: | ||
#280
Yea kinda weird hes having problems with task manager yet im running the same rom and it works great ?Id try a hard reset again see if this time around he gets it working.
#281
Sure did. What would happen if I used Total Commander and deleted everything related to Dotfred task manger? hmmmmmm?
The Following 2 Users Say Thank You to ebuzz For This Useful Post: | ||
#282
Probably wounldnt go over well with your phone lol , have you tried a different rom lots great one's out there right now !!!
#283
I'd rather not flash to another ROM, too much of a pain to reinstall all my apps over and over again. I'll just do w/o this task mgr or install a different one.
The Following 4 Users Say Thank You to ebuzz For This Useful Post: | ||
#284
there's everything on here.....if you look hard enough.......or someone produces the link!
The Following 3 Users Say Thank You to only1penny For This Useful Post: | ||
#285
Can i get some help with the windows media player? I can't get it to work and the touchflo album viewer won't play videos.
#286
hey quick question in this rom how do you send pics? or do i have to install my on pics sender cab or something of the sort cause at the moment i doesnt really give me a option to send pics to other phones or is it hidden some where ?
The Following User Says Thank You to Omega For This Useful Post: | ||
#287
“ Originally Posted by Omega ”hey quick question in this rom how do you send pics? or do i have to install my on pics sender cab or something of the sort cause at the moment i doesnt really give me a option to send pics to other phones or is it hidden some where ?
Codehttps://www.smartphonejunkie.org/sprint-arcsoft-52122-t188638.html?t=188638 |
The Following 5 Users Say Thank You to iamdasht19 For This Useful Post: | ||
#288
this rom is fast and very responsive, however what happened to the programs tab for the tf3d2 version, is there a way to get that on here?
The Following 2 Users Say Thank You to jrodri62 For This Useful Post: | ||
#289
this is a very old rom with old software and drivers, you amy want to consider moving up to a new one like nrgz, gokus, nfsfan, etc.. those have the newest and most up to date things included, including the tab that you desire.
#290
so i flashed the titanium version of this twice. both times i haven't gotten the new 6.5 interface to come up. is that by design, or am i somehow doing something wrong? great speed however with what i've seen so far.
#291
did you go to start/settings/today/items/ and than change it to windows default? touchflo is default if your not using the titanium version
#292
“ Originally Posted by D/\SH ”did you go to start/settings/today/items/ and than change it to windows default? touchflo is default if your not using the titanium version
--------- New Post Merged on 14/8/2009 at 1150 -------- anyone else having an issue with the weather having a big red X instead of showing? other than that, i think this is my favorite rom for the time being. --------- New Post Merged on 14/8/2009 at 0225 -------- “ Originally Posted by
The Following 2 Users Say Thank You to spidermonkey21 For This Useful Post: | ||
#293
“ Originally Posted by jrodri62 ”this rom is fast and very responsive, however what happened to the programs tab for the tf3d2 version, is there a way to get that on here?
--------- New Post Merged on 19/8/2009 at 1049 -------- OK, After going through a crap load of roms and finding the right third party apps to run on (and work correctly) I have chosen this to be my stop all rom till something crazy comes out...... Everything works great BUT in the Power menu under Advanced the check box for "turn off decice if not used for" keeps un-checking itself. This will happen if I restart or something. Its not a reason to flash again but it's annoying. ANY HELP???? |
#294
Will there ever be an update to this rom?
#295
highly doubt it, havent seen much from the developer in months even in activitiy form.
#296
Re StarROM 20 (The New Beginning WM 65 5221222
Too bad he put out some great roms !!!
#297
yeah, that is too bad. Can anyone tell me the name of the dialer atleast? I like the small dialer alot and all my co-workers digg it. Been searchin through alot of dialers and cant find it. If anyone can give me the name of a cab file link, I would really appreciate it.
#298
ya it's too bad about the updates because i really liked this rom. i tried it right when 2.0 came out just to see and ended up staying on for awhile.
#299
Hi All is there any way to get the opera that was used in this ROM in a different ROM I really like the format of the opera that was used in this ROM. Any help would be greatly appreciated.
Thanks! |
Tags |
beginning, starrom, [htc-pro] |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
StarROM 20 WM 65 5221222 | Superman369 | Review | 5 | 06-05-2009 07:06 PM |
Droid - The Beginning - V1.1 | iamdasht19 | WM Mobile Games | 2 | 02-19-2008 09:00 PM |
Beginning Visual C++ 2005 | cades142 | (Home) Pc Applications | 1 | 03-05-2006 09:27 PM |
New Beginning | puertoblack2003 | Random Community Topics | 0 | 11-10-2005 02:10 PM |
Layout Options | Width:
Fixed
Contact Us -
SPJ Bulletin -
Archive -
Privacy Statement -
Terms of Service -
Top
