OmegaOne Battery Pack Pro v3.2.0
Requirements: Any Pocket PC 2002 device or newer Overview: View battery life, storage cards, launch apps, keep your system optimized & adjust brightness on your today page! Battery Bar Displays Battery, Memory, Storage Card, Network connection, Time, World Time & backlight data on the today screen. Tap on each section for detailed info. Speaks to you when your battery, memory or storage cards are low. Battery Bar shows battery remaining in hours & minutes, tailored to how you use your Pocket PC. Program Bar Launch programs from your today screen. Tab view allows as many program links as you wish. Host other today plug-ins as a tab in Program Bar to save valuable screen real-estate. Search Bar Search the web, open URLs, search for telephone numbers, addresses, business listings or get driving directions. Calendar Bar View the next 50 appointments, or switch the view to display the calendar for this or other months. Power Start Tap & hold the start button to show a list of icons you can customize yourself. The icons are big, so you can launch programs without having to reach for your stylus. Power Time World time view. See where it's daylight, or check when your friends / customers are awake or at work. Automatically grabs the latest exchange rates & current weather conditions for each city. With Journal Bar installed, displays the current 5 day forecast for each city. Get detailed information about each city. Power Task Close button actually closes programs. Speed up your Pocket PC by closing slowly running programs taking up lots of memory. Keep your Pocket PC running as fast as the day you bought it! Power Bars Displays the battery, memory, storage card life, time, date and time until next appointment on the title bar - see your Pocket PCs vital statistics all the time. Power Clean Reclaim valuable space by removing unwanted files automatically. Power Alert Adjust Calendar, Task & Alarm sounds to repeat, change volume & more. Keep reminders quiet during meetings; have unique sounds so you know what the alert is! Power Store Provides even more detailed battery, memory and storage card information. Keep a track on your battery, memory & network usage with graphs which show your usage over the past 24 hour period. Power Adjust Customize your Pocket PC with lots of cool tricks, including different system fonts & animated windows. Power Light Don't fumble with the keys in the dark - turn your Pocket PC screen into a flashlight, or a warning light for emergencies! New in v3.2.0 (22nd September 2007) - Supports WVGA (800x480) and 480x480 resolution devices. - Added feature to Power Adjust to edit the Internet Explorer home page. More Info: Code: http://www.omegaone.com/batterypack/pro/default.htm Download Instructions: http://rapidshare.com/files/68891592...erial.rar.html Mirror: http://www.megaupload.com/?d=8F0PRMUO http://www.filefactory.com/file/adf5d8/ http://depositfiles.com/files/2329294 |
Re: OmegaOne Battery Pack Pro v3.2.0
once again had issues with the exe version.Googles foud the cab for it.
Codehttp://www.omegaone.com/downloadthanks.php?Device=pda&Product=BPP-PPC
Tags |
battery, omegaone, pack, pro |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Battery Pack Pro 1.5 | iamdasht19 | WM And PPC Applications | 0 | 03-20-2008 04:10 AM |
Battery Pack Pro 2.1.3 | iamdasht19 | Palm OS Archives (Old Platform) | 0 | 05-02-2007 10:26 PM |
Layout Options | Width:
Fixed
Contact Us -
SPJ Bulletin -
Archive -
Privacy Statement -
Terms of Service -
Top
