Best docking stations for 24-inch iMac (M3, 2023) in 2023 – Smart Fone Video Blog
Grab one of these docks to make the most of your new M3-powered iMac.
Apple’s 24-inch iMac (M3, 2023) is easily one of the best Macs out there in 2023. The much-needed 2023 iMac refresh brings the company’s latest silicon chip and faster Wi-Fi to the table, improving an already excellent desktop computer for those who prefer a stationary setup for working from home. I just wish the new 24-inch iMac had more ports, because the current selection is quite limited. You really only have a couple of Thunderbolt ports and a headphone jack, just like its predecessor. It’s nothing a Thunderbolt dock can’t solve, though, and there are plenty of them available on the market right now.
There’s no shortage of Thunderbolt docks on the market in 2023, and we gathered some of the best ones in the collection below for you to check out. Let’s dive in!
Best docking stations for 24-inch iMac (M3, 2023) in 2023: Bottom line
The docks highlighted in the collection above, as you can see, has a bunch of solid options that’ll work well with Apple’s new 24-inch iMac. The M3 chip is a bit limited in its capabilities when it comes to support for external monitors, but you’ll still be able to make good use of the docks from the list above. I’d personally go with something like the Plugable TBT4-UDZ with a bunch of fast USB-C ports, a super-fast 2.5Gbps Ethernet, and more. It’s also not nearly as expensive as the CalDigit TS4 dock, despite adding almost the same ports.
I’ve also added a good mix of both affordable and more expensive options to the collection, so feel free to explore the entire list before checking out your cart. Just keep in mind that you’re probably not going to need all the bells and whistles of a high-end dock with things like multiple monitor support and power delivery for the iMac, so you can even choose to go with something less fancy like the Baseus 13-in-1 USB hub. Also, if you haven’t bought the iMac already, then you might want to check out the links below to find the best price for it online right now.
New Project-2-12
2023’s 24-inch iMac receives a notable processor bump from Apple M1 to M3, along with Wi-Fi and Bluetooth upgrades. It still retains the same number of ports its predecessor, though, so grab one of the docks highlighted above.
