Best docking stations for Lenovo Slim Pro 9i (2023) – Smart Fone Video Blog
Enhance your Lenovo Slim Pro 9i by adding ports with one of these docking stations.
For any creator, the need for a great laptop that allows you to edit videos, photos, and audio is a must. You need a PC that can handle a lot and keep running, no matter where you’re using it. If you’re in the market for one of the best laptops for multitasking, the Lenovo Slim Pro 9i should be on your list. It offers great graphics, powerful processing, and a fantastic mini-LED display. There are also a ton of ports, but you can add more. If you’re going to be using the Lenovo Slim Pro 9i and want to take advantage of your desk space by adding additional monitors or handling transfers, here are the best docking stations to get your work done.
  • Kensington Triple-Display USB-C Docking Station SD4839P
    Editor’s choice
    $80 $220 Save
    $140
    The Kensington SD4839P is a supreme docking station because it allows you to hook up three monitors, two of them at 4K. It also delivers 85W of power charging and transfer at speeds up to 10Gbps. There’s an HDMI port, two DisplayPorts, one USB-C 3.2 port, three USB-A 3.2 ports, an Ethernet port, and an audio jack.
  • wavlink-docking-station
    WAVLINK Enterprise-Level Universal Docking Station
    Premium pick
    $370 $400 Save
    $30
    You’ll be blown away by the amount of ports this premium WAVLINK docking station offers. You get 20 ports and have the ability to hook up four displays at once. There are multiple USB-A, USB-C, and Thunderbolt ports. It can also run 2.5GB Ethernet, and it has an SD/TF card reader.
  • 01-1
    Anker 341 7-in-1 USB-C Hub
    Best value
    If you are looking for a great value, the Anker 341 dock delivers. You’ll get an HDMI port, multiple USB-C and USB-A ports, an SD card reader, and more. It won’t take up a ton of space and will cost you much less than others on this list.
  • Lenovo ThinkPad Universal Thunderbolt 4 Dock
    Source: Lenovo
    Lenovo official dock
    $196 $300 Save
    $104
    This docking station from Lenovo is great for the Slim Pro 9i because it gives you the opportunity to add four monitors. Because it’s a Thunderbolt dock, it delivers up to 100W of power to keep your devices running and has four USB 3.2 ports, one USB-C port, multiple DisplayPorts, an HDMI port, and so much more. You’ll enjoy fast data transfer speeds and a ton of variety for connecting devices compared to other non-Thunderbolt docks.
  • baseus
    Baseus 17-in-1 USB C Docking Station
    Most versatile
    $120 $133 Save
    $13
    Another option with a ton of ports, this offering from Baseus offers a sharp stand that clears up desk space by sitting vertically. You’ll get 100W of power delivery, four USB-C ports, and three HDMI ports that allow you to hook up multiple displays. There are also five USB-A ports, giving you a ton of versatility.
  • CalDigit TS4 Thunderbolt 4 Dock
    Source: CalDigit
    More Thunderbolt ports
    $400 $450 Save
    $50
    If you’re looking for a Thunderbolt dock that’s sharp and incredibly effective, don’t look past this from CalDigit. There are 18 ports, including Thunderbolt downstream ports, numerous USB-C and USB-A ports, and a 2.5GB Ethernet port that gives you added speed, unlike other docking stations that aren’t a Thunderbolt dock. This is also one of the sleekest docks on the market.
  • Plugable Triple 4K Docking Station
    Plugable UD-ULTC4K
    More USB-A ports
    If you want USB-A ports, you get four of them with this docking station from Plugable. It extends your abilities with the Slim Pro 9i, as there are both DisplayPort and HDMI ports. You’ll be able to use three 4K 60Hz displays at the same time. Unfortunately, it doesn’t use Thunderbolt though.
  • Lenovo__1_-removebg-preview-1
    Anker 655 8-in-1 USB-C Hub
    Most compact
    For those who are concerned about fitting a docking station on their desk, the Anker 655 is a great pick. It measures under five inches in size and just over five ounces in weight. But you’ll get HDMI, USB, 1Gbps Ethernet, SD card readers, and more in this compact hub.
Leave a Reply
