Learning how to right-click is essential to control your Apple computer.
If you just bought a new Mac and are using macOS Sonoma for the first time, then you may not know how to right-click. After all, right-clicking on Windows laptops isn’t the same as on Apple computers. The purpose of a right click remains similar: bringing up a menu of relevant options, for the most part. The execution, however, varies, and we will be detailing how to right-click on Mac below.
How to right-click on Mac using a mouse
Right-clicking with a mouse is as basic as you’d expect it to be, whether you have a Magic Mouse or a third-party mouse.
- If you have a Magic Mouse, click on the right side of its top surface.
- If you have a traditional, third-party mouse, click the right button on the top.
- If you have a mouse with a peculiar design, check the included manual or the manufacturer’s website.
Right-clicking with a trackpad
Apple gives trackpad users three options to choose from when it comes to right-clicking on a Mac. Here’s how to customize yours based on what works best for you.
- Launch the System Settings app.
- Click on Trackpad towards the bottom.
- Make sure you’re in the first section of the top bar, titled Point & Click.
- Click on the little arrows next to Secondary click. Secondary click is how Apple refers to the right-click functionality.
- You will get three options to pick from:
- Click or Tap with Two Fingers
- Click in Bottom Right Corner
- Click in Bottom Left Corner
- Try them all, and choose the one you prefer.
How to right-click using the default keyboard shortcut
If you tend to keep one hand on the trackpad and another on the keyboard, then you may appreciate this method:
- Using the trackpad, move the cursor to where you want to right-click.
- Click and hold the Control button on your keyboard.
- Tap the trackpad.
- Release the Control button.
How to set a custom keyboard shortcut
If you like the idea of tapping a keyboard button to trigger a right click but don’t want to rely on the Control button for that, you can set a custom shortcut.
- Head to Accessibility.
- Scroll down, and enter the Pointer Control section.
- Enable the Alternate pointer actions toggle.
- By default, the F12 button will trigger a right click going forward.
- To change the mapped button, tap on the (i) next to the toggle you just enabled.
- Double-tap on the Right Click option listed.
- Click Reassign.
- Tap any button on your keyboard to set it as the new right-click shortcut.
- Hit the Done button.
- Click OK.
- Going forward, move your cursor to where you want to right-click, and hit the chosen button on your keyboard to trigger the action.
Personally, I use the Tap with Two Fingers trackpad option because tapping is faster than clicking, so this choice integrates well with my workflow. While it may sound like a minor difference, placing your fingers on the trackpad’s surface without applying any pressure to click makes a difference when you spend full work days interacting with a Mac. Ultimately, you can try all of the options and pick the one that feels natural to you.
