Roborock debuts new Q5 Pro & Q8 Max Robot Vacuums, with new Dyad Pro Combo at IFA 2023 – Smart Fone Video Blog
Roborock has not only announced a new all-in-one washer dryer at IFA, but also two new robot vacuums and a new wet-dry vac.
Let’s start off with the new robot vacuums. Roborock is introducing the new Q5 Pro and Q8 Max. These are the latest in the Q-series for Roborock. While the Q5 Pro is an entry-level option, the Q8 Max offers advanced intelligence like the obstacle avoidance system.
Both of these robot vacuums come with Roborock’s new DuoRoller Brush system. This debuted on the S8 series earlier this year. That combines with 5,500Pa suction power, giving users a top-tier cleaning performance.
Roborock has also include LiDAR on both models, for a great navigation experience. And they have proven mopping systems, giving you simultaenous vacuum and mopping compatibility. Both models are also available with a plus counterpart – Q5 Pro+ and Q8 Max+. Which includes the RockDock Plus auto-emptying dock.
Both models will be available starting in early October. The Q5 Pro will be $429, while the Q5 Pro+ will be $699. The Q8 Max will cost you $599, and the Q8 Max+ is going to be $819.
Roborock Q5 Pro
Roborock Q8 Max
A convertible wet-dry vac
Roborock also showed up in Berlin for IFA with a convertible wet-dry vac – Dyad Pro Combo. This is like the Dyad Pro that Roborock announced earlier this year, but this is a convertible unit. So it can convert into a handheld vacuum – like the H7.
With the Dyad Pro Combo, Roborock includes four additional attachments, so that it can be converted from a wet-dry vacuum to a cordless handheld vacuum for different cleaning scenarios. It also boasts about 17,000Pa of suction power here, and can clean as close to 1mm from edges and corners. It allows it to clean on all surfaces.
Like with the other Dyad models, it does have easy maintenance and a self-cleaning system. Which is going to clean its roller brushes with water and it will also dry it, to help combat the spread of bacteria. It has a prolonged runtime of about 43 minutes as a wet-dry vac or 60 minutes as a handheld vacuum.
The Dyad Pro Combo will be available in early October, and will cost $659.
