Upgrade your PC for less with MSI motherboards, power supplies and more starting at $20 – Smart Fone Video Blog
Don’t miss out on fantastic deals on motherboards, PSUs, AIO, and more.
There are a lot of critical components when it comes to building a PC, and while the process can be fun, sometimes it can be a little daunting if it’s your first time. Luckily, there are now wide range of quality options, making it more affordable than ever to build your own computer.
Of course, finding the best prices on some great components is always the way to go, and as you might expect, we’ve found some excellent deals on MSI motherboards, power supplies, active cooling, and more. So if you’ve been thinking about building a new PC, or just needed to upgrade some components, be sure to check out these sweet deals from MSI.
Motherboard
  • MSI MPG Z790 Edge WiFi Gaming Motherboard
    $310 $380 Save $70
    The MSI MPG Z790 Edge motherboard supports Intel’s 12th and 13th Gen processors and DDR5 RAM and features built-in Wi-Fi connectivity.
  • msi-pro-z790-a
    MSI PRO Z790-A WiFi Gaming Motherboard
    $215 $280 Save $65
    Compatible with Intel’s Raptor Lake processors, the MSI PRO Z790-A motherboard features built-in WiFi connectivity on top of supporting DDR5 RAM sticks.
  • The MSI B550-VC PRO ProSeries motherboard.
    MSI PRO B550-VC ProSeries
    $100 $140 Save $40
    MSI’s B550-VC PRO ProSeries is an AM4 motherboard with support for PCIe 4.0 SSDs and GPUs, and has a midrange 10+2+1 stage VRM.
Power Supply
  • Untitled design Background Removed-24
    MSI MPG A1000G
    $150 $200 Save $50
    A 1000W full modular ATX 3.0 PSU with an 80 Plus Gold certified rating.
  • Untitled design (1) Background Removed-1
    MSI MAG A850GL
    $120 $140 Save $20
    An 850W full modular ATX 3.0 PSU with 80 Plus Gold certified rating.
AIO
Accessories
Untitled design Background Removed-26
MSI Vigor GK20
$20 $30 Save $10
As you can see, there are a lot of great discounts to be had, but you’re going to need a few more parts to complete your build like RAM, which comes in DDR4 and DDR5 kits, an Intel or AMD CPU, internal storage, graphics card, and PC case. Now, if this is your first time making a PC from scratch, don’t worry, we’ve got you covered and can walk you through it step by step with our detailed beginners guide to building a new PC.
