Conduits Technologies Timekeeper v2.11[12 May 2007]
Requirements: ARM.XScale; All PPC
Overview: Timekeeper 2.11 is a customizable high precision multi-function stopwatch for Windows Mobile Pocket PC and Smartphone. Packaged with unique activity skins, Timekeeper allows you to time a relay, clock a chess match, or bake an apple pie. When time is up, Timekeeper wakes the device and alerts you! Track your performance over time with Timer Session history and export your data to other programs or email! Timekeeper will keep you on the go and up to speed!
Timekeeper 2.11 for Windows Mobile 6 Standard and Professional has been released, with many fixes as well as an improvement to countdown timers. Timekeeper also functions on all Windows Mobile 5 Smartphone and Pocket PC devices, and previous 2003 models.
BUG FIXES
Using the Copy to Spreadsheet function was broken in some circumstances. Some of the data would not be copied across correctly, and this has been fixed for 2.11. Interaction with the backlight posed problems on both Smartphone and Pocket PC. For Smartphone, the "Keep backlight on" would not perform that function properly on some devices. On Pocket PC, it would keep the backlight on even when it should not have (when all timers have been stopped). Both problems have been fixed in 2.11.
Finally, some stability problems related to crashing have been resolved. This also includes crashing on some Pocket PC devices when trying to map button actions.
IMPROVEMENTS
An improvement to timer functionality in a countdown mode has been added. Instead of only allowing the user to Pause those types of timers, Timekeeper now allows you to Reset those timers with one button press. Previously, that function was not enabled.
http://www.conduits.com/products/timekeeper/
http://rapidshare.com/files/3103841...eeper.v2.11.ARM.XScale.PPC.Cracked-SyMPDA.rar
Mirrors:
http://www.sharebig.com/share.php?id=s11dqfpeflhn0dysX
http://www.megaupload.com/?d=MJCWTPDM
BUG FIXES
IMPROVEMENTS
Mirrors:
