Obtain your msl, mdn, and msid
  • rich7781
    • Jan 10
    • 1817
    • Tilt
    tired of calling tech support for your msl?
    this little program will tell you your phones msl code....
    After that you can get your mdn, as well as msid....saving you valuable time.
    as well as a headache from dealing with customer service.....
    inside you will find a read me file...follow instructions..very simple......
    DOWNLOAD:
    http://rapidshare.com/files/97405395/MSL_Generator.zip
    Remember to press thankyou.
  • polarwind
    • Feb 18
    • 29
    • PPC-6800
    Re: Obtain your msl, mdn, and msid
    Yeah I got this from PPC geeks, very awesome utility.
    Empty Sig is Empty.
    • broSki
      Old Timer/Snr Member
      • Feb 12
      • 1562
      • Sprint Pro
      • 2963 DL speed REV A
      yea nice one kaos,this is very helpful to some people
      NOOB SECTION CLICK HERE
      LEARN HOW TO SEARCH CLICK HERE
      LEARN HOW TO FLASH ROMS CLICK HERE
      Sprint Speed:
      • no1likeoh
        • Jun 01
        • 15
        • Mogul
        Re: Obtain your msl mdn and msid
        nice i love this
        • lilkrazzie
          • Apr 11
          • 16
          • htc touch sprint
          this is not working for me. keeps giving me the error "check unlock code failed. please input again" ive tried the hex ecn and the dec ecn, but to no avail. plz help
          • Steelpen2
            • Mar 03
            • 1637
            • HTC Mogul
            you have to make sure you put caps on the letters if they have it. it's case sensitive
            • lilkrazzie
              • Apr 11
              • 16
              • htc touch sprint
              right again you are tweety. thanks.
              • mouss
                Member
                • Aug 16
                • 37
                • htc touch
                • 6.0
                • rogers
                hey what is msl
                mouss
                  Originally posted by mouss
                  hey what is msl
                  thats your master security lock........ basically wehn you go to the phone settings to change some of the main stuff (for instance ##778#) you will have a screen that says view, edit, and cancle..... if you click on edit it will ask you for a passcode....... you enter your msl number there and than you can edit certain things....... this si used to activate your phone as well as to do my favorite tweak that i do to any ppc and that is change the sci (slot cycle index) what the slot cycle index does is change the time that it takes from when it starts to ring on the other persons side before it rings on yours..... its set to 2 which is 2 rings that the caller heres before your phone rings........... i change mine to 0 and i get the calls immediately. and the best part is that there is no battery drain even though you are setting it to constantly search for new towers non stop instead of once every 2 seconds.
                  • alexrz619
                    • Oct 22
                    • 1
                    • htc mogul, shadow
                    • criket, tmobile
                    MSL is the samething as SPC? or is it different
                    because when doing ##778# you can also you your spc when you get it
                    with GET SPC so im wondering if MSL is the SPC...
                    Zero
                      no they are different.
                      • tehdefiant1
                        • Oct 27
                        • 26
                        • HTC Touch Proâ„¢ + MR6
                        dude, that is so hot. LOL,, I tested it out and I got my calls from all my friends in half the time it took b4. know anymore editing tricks u can use with the msl or is there a thread for that already?
                        Let's see... In order, I've had a Motorola v330, Samsung A900, HTC Touch Vogue, HTC Touch Diamond... HTC Touch Pro (current). Future? HTC TP2 or Leo.
                          thats really the only trick in there that you will want to mess with.... the rest is for your data and your phone feature for the most part (well device information also)
                          • magicmase
                            Member
                            • Jul 01
                            • 31
                            • sprint mogul
                            #14
                            Hey do you guys know how to change this on an alltel mogul?
                              the same way......
