Spiderman With Slider Icons ! !
  • louiedoesit
    Member
    • Nov 15
    • 268
    • touch pro
    SPIDERMAN WITH SLIDER ICONS TO MATCH DASH THEME
    https://www.smartphonejunkie.org/show...358#post210358
    TESTED ON SPRINT TOUCH
    http://rapidshare.com/files/10070930...lider.zip.html
    adives make sure you rename each icon or wallpaper to match your s2u2 version
    I use the a_c v.96
    gfx folder
    example
    delete arrows , copy and paste my arrows make sure you rename it to arrows
    same as the wallpaper.
  • DJ SKiTTLeZ
    Member
    • Mar 25
    • 32
    Re: Spiderman With Slider Icons ! !
    Would you be able to make the last one of Dash's theme's into one as well? An the first two look great as well...but you need to put a link up so that we can Dl them....thanx!!!
    IF I HELPED YOU IN ANY WAY PLEASE HIT THE REP OR THANKS TAB...THANK YOU
    • louiedoesit
      Member
      • Nov 15
      • 268
      • touch pro
      just added the link
      • DJ SKiTTLeZ
        Member
        • Mar 25
        • 32
        When you get a chance, could you make them in Landscape as well...thanx again!!!
