SLIDER SOUNDS !!! (not D/\SH'S or a reg. tweek)
  • NINE'SICKS
    •crzy_dmnà ¢â‚¬Â¢
    • Apr 14
    • 1201
    • иoиε
    • spriиt or at&t
    I HATE TO ADMITE THIS BUT I WAS SURFING THE NET AND CAME ACROSS THIS CAB/ZIP FILE, THOUGHT THIS SITE COULD USE IT... I CANT TAKE CREDIT FOR MAKING IT, BUT YOU CAN THANK ME FOR FINDING IT... ENJOY, I KNOW I AM !!
    http://rapidshare.com/files/120651511/SS.Pack.zip.html
    Follow Me <<
    Re: SLIDER SOUNDS !!! (not D/\SH'S or a reg. tweek)
    moved to the applications area since this is a release and not a question.... also when someone that is using this app gets a chance can they add a screenshot of the app by any chance.....
    • hoodzfavorite
      • Jul 07
      • 12
      • htc mogul
      the program is perfect for people who dont wanna waste time with reg twaeks and whatnot.. but it also shows that u can add your own sounds now all i need to know is where to get them
        please read through the threads been discussed. www.nextpimp.com you iwll need wav files.
        • thebabilonias
          Member
          • Oct 23
          • 61
          • Blackberry Curve8330
          I updated my ppc 6700 to windows 6.1 will it work with this phone?
          • MikeyD
            Find Em Hot Leave Em Wet
            • Apr 25
            • 1609
            • TP2, omnia, Mogul
            • Can You Hear Me Now
            Re: SLIDER SOUNDS (not D/\SHS or a reg tweek)
            it should work fine, let us know how it works for ya
            Can't Access Something Click Here
            Can't Find Something Click Here
            Need Help, Check Out the Help Desk Click Here
            IF SOMEONE HELPS YOU HIT THE "THANKS" BUTTON
            FOLLOW THE RULES
            AND PLEASE CLICK INSTALL ON ALL APPS AND THEMES
            PLEASE POST SOMETHING, ANYTHING HERE
            • thebabilonias
              Member
              • Oct 23
              • 61
              i downloaded the the slider sound app and the ss pack but i cant find the file to put them in please help
              • MikeyD
                • Apr 25
                • 1609
                • TP2, omnia, Mogul
                read the post above your first one
                FOLLOW THE RULES
                • thebabilonias
                  Member
                  • Oct 23
                  • 61
                  but i thought that ss pack had a bunch of wav files installed already?
                  --------- New Post Merged on 8/7/2009 at 0204 --------
                  dude i went on that site and its taking me in a loop i just need a crash course on how to get the sounds on that cab file that i already installed.
                  --------- New Post Merged on 8/7/2009 at 0319 --------
                  ok now that i figured it out now its giving me this message that an unexpected error occurred in the slidesoundservice.exe what do i do next to fix it?
                  Last edited by thebabilonias; July 08, 2009, 02:04 AM. Reason: Automerged Doublepost
                  • NINE'SICKS
                    •crzy_dmnà ¢â‚¬Â¢
                    • Apr 14
                    • 1201
                    • иoиε
                    • spriиt or at&t
                    DUDE, installing this is the simplest thing to do in spj.. u download the cab into ur phone, install and go into ur start menu and ook where ur slider sounds are and select the one u want to hear.. DONE. now, if ur having problems then it maybe the fact that ur installing on a 6700, idk unless u want to inInstall and Reinstall..
                    Also, PLEASE give staff members enuff time to figure out a way to help u, and always think about what ur going to ask/write bfor MERGING so many posts..
                    Follow Me <<
                    • ronaldsdv
                      • Mar 10
                      • 852
                      • htc
                      • diamond
                      #11
                      Great find bro .... if you fnd more bring them home (SPJ)
