here is a matching welcome screen for the SPJ theme I made. just copy to your ppc windows folder. enjoy...
SPJ-welcomescreen-PROBEX
Re: SPJ-welcomescreen-PROBEX
This is Sicksigpic
If I Have Helped Be Sure To Hit That Thanks Button!!!Comment
im using kaos take 5, would that be the reason why i cant copy this file to my windows folder? i keep getting a error copying file message......sigpic
NEW TO SPJ? CLICK HERE
NEED TO LEARN HOW TO FLASH? CLICK HERE
QUIERES SABER COMO DESBLOQUEAR Y FLASHAR TU TELEFONO? PRESIONA AQUI
TIENES PREGUNTAS SOBRE APPLICACIONES O TEMAS, PERO NO SABES HABLAR INGLES? PRESIONA AQUI
you unziped it first then moved only the image correct? Just clarifing I don't see any reason why it would fail, but here is a trick that may help. If you look inside the windows folder and find the current welcomehead.96.png file rename it to welcomehead.96.png.old and then upload this one to the windows folder, that way even if there is read only or something applied to the original it will still replace it.Comment
in my windows folder the only welcomehead.96.png is this one i put in it...assuming it replaced the old one, buuuut nothing on startup....still got the htc welcome screen....any advice?Comment
are you using something like total commander or resco file explorer 7.05 to overwrite the image files in the windows folder?Comment
