Whats up to my spj fam. Been awhile.But i finally got my exe issues sorted out. Now some of you like my roms. some like but wanted some different things...So I'm a do it like this. Here will be two versions of my take 3. One more politically correct. One same old raw attitude.So hope you enjoy.
THIS IS A WORK IN PROGRESS. THIS IS DESIGNED SPECIFICALLY FOR THE HTC SPRINT MOGUL.FLASHING THIS ROM MAY/WILL RUIN YOUR DEVICE.
MYSELF & SPJ ARE NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR DEVICE.
Kaos's **** Sprint Custom Rom Build 420 Take 3
My Rom is based off of nueROM v2.0, build 5067 with some stuff removed some added...all and all very stable...
Take 3 release 1
pics in this order
Radio splash,main splash,Loading Gif,Windows boot Screen
Take 3 Release 1 Build Log
based on sprint 3.49
xip restructure (3.49-NO2-A)
patch certmod
update drivers
switch to 19208
disable ipv6
disable software disable dialog service
disable smartcard support (scard.dll, winscard.dll)
disable WWAN (simulate disable SYSGEN_CELLCORE_WWAN)
disable WAP,WLTS,WDP (simulate disable SYSGEN_CELLCORE_WAP)
disable error reporting transfer driver (dwxfer.dll)
delete simsec.dll, sim card security functions
delete tkitapp.exe, sim kit app
delete siminit.dll, sim init functions
sprint/vzw: enable call forward, call wait options, change sms callback num, etc
nuefirstboot agent updated to build 101
Now based on 3.35.671.9 (Alltel build)
Update SYS files with latest versions from most recent kaiser rom
BT updated (HCI = 3.51.0)
zlib updated to faster v1.2.3 (for some reason, MS was using version 1.1.3 with security issues...)
Clear storage updated to 1.33.0
DeviceInfo -> 1.18.0
XIP restructured (3.35-NO2-B): note - certmod patch not done yet
resolve several memory related issues from 5060
nueshutdown (hold down power button)
nuefirstbootagent
nuelinks
nuepackageinstaller
nuepackagediagnostics
nueprovxmlloader
multiple carrier support thanks to tiermann and nexvision
advanced config readded
pim backup readded
.fred taskmanager readded
weatherpanel compatibility verified
multi-sip compatibility verified
-WM6.1 (CE OS 5.2.19208 Build 19208, AKU 1.0.2)
-Clean
-NETCF3.5/SQLCE3.5
-3.xx Series ROM
-GPS
-multicarrier
-Startup animation gif enabled
-10 Button Comm manager
-AdobeReaderLE
-Office Excel
-Office PowerPoint
_Office Word
-One Note
-Phm NotePad
-Solitare & Bubble Breakers Readded
-HTC Finger Friendly title Bar
-psshut
-Sprint Music Store Added
-Java Client added (Required to use music store)
-HTC Windows Media Player Skin assortment
-SprintTv
-Net Framework 3.5
-Htc Ringtones added
-HTC Performance
-Oxis Memory
-HTC Smart Dialer
-BlueFrog Bigbutton dialer
-ie res
-Ie Warning Screens Turned off
-Scroll Thickness Set to 9
No SMS sent Notification popups
-Battery Performance enhanced
-B2A2DP Tweaks
-hided data Connection Bubble
-Skinny Signal Bars added
-HTC sliding sounds
-ClearTemp
-Startclean
-Autoupdate for wm6.1 applied
-SqlCeMobile 3.5
-quickmenu
-Advanced Config added
-Microsoft Voice Commanded
-nueEXt Rom Config
-NueLED Driver Control
-Font set to calibri
-TouchFlo
-1cal calculator
Download:
Ok This Is my Stripped
Take 3 Release 2 Build Log
THIS IS WHAT IM RUNNING
everything as above except.
games stripped
sprinttv gone
welcome center gone
sprint music store gone
DOWNLOAD:
please remember if you like my work.Please donate.Even a dollar helps out.link next to avatar.
Take 3 release 1
pics in this order
patch certmod
update drivers
switch to 19208
disable ipv6
nuefirstbootagent
nuelinks
nuepackageinstaller
nueprovxmlloader
pim backup readded
-Clean
-NETCF3.5/SQLCE3.5
-3.xx Series ROM
-GPS
-multicarrier
-AdobeReaderLE
-Office Excel
-Office PowerPoint
_Office Word
-One Note
-Phm NotePad
-psshut
-SprintTv
-Net Framework 3.5
-HTC Performance
-Oxis Memory
-HTC Smart Dialer
-ie res
-B2A2DP Tweaks
-HTC sliding sounds
-ClearTemp
-Startclean
-SqlCeMobile 3.5
-quickmenu
-nueEXt Rom Config
-TouchFlo
-1cal calculator
Download:
http://rapidshare.com/files/127987181/RUU_signed.nbh
games stripped
sprinttv gone
welcome center gone
DOWNLOAD:
http://rapidshare.com/files/127835750/RUU_signed.nbh
