THIS IS A WORK IN PROGRESS. THIS IS DESIGNED SPECIFICALLY FOR THE HTC SPRINT & OR ALLTEL MOGUL.FLASHING THIS ROM MAY/WILL RUIN YOUR DEVICE.
MYSELF & SPJ ARE NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR DEVICE.Kaos Hybrid Take 3 enhanced
My Rom is based off of nueROM v2.0, build 5067 with some stuff removed some added...all and all very stable...
Take 3 Hybrid
pics in this order
Radio splash,main splash,Loading Gif,Windows boot Screen
Take 3 Hybrid BuildLog
based on sprint 3.49
xip restructure (3.49-NO2-A)
patch certmod
update drivers
switch to 19208
disable ipv6
disable software disable dialog service
disable smartcard support (scard.dll, winscard.dll)
disable WWAN (simulate disable SYSGEN_CELLCORE_WWAN)
disable WAP,WLTS,WDP (simulate disable SYSGEN_CELLCORE_WAP)
disable error reporting transfer driver (dwxfer.dll)
delete simsec.dll, sim card security functions
delete tkitapp.exe, sim kit app
delete siminit.dll, sim init functions
sprint/vzw: enable call forward, call wait options, change sms callback num, etc
nuefirstboot agent updated to build 101
Now based on 3.35.671.9 (Alltel build)
Update SYS files with latest versions from most recent kaiser rom
BT updated (HCI = 3.51.0)
zlib updated to faster v1.2.3 (for some reason, MS was using version 1.1.3 with security issues...)
Clear storage updated to 1.33.0
DeviceInfo -> 1.18.0
XIP restructured (3.35-NO2-B): note - certmod patch not done yet
resolve several memory related issues from 5060
nueshutdown (hold down power button)
nuefirstbootagent
nuelinks
nuepackageinstaller
nuepackagediagnostics
nueprovxmlloader
multiple carrier support thanks to tiermann and nexvision
advanced config readded
pim backup readded
.fred taskmanager readded
weatherpanel compatibility verified
multi-sip compatibility verified
-WM6.1 (CE OS 5.2.19208 Build 19208, AKU 1.0.2)
-Clean
-NETCF3.5/SQLCE3.5
-3.xx Series ROM
-GPS
-multicarrier
-Startup animation gif enabled
-10 Button Comm manager
-AdobeReaderLE
-Office Excel
-Office PowerPoint
_Office Word
-One Note
-Solitare & Bubble Breakers Readded
-Manilla today Theme Tsk.
-HTC Finger Friendly title Bar
-HTC Windows Media Player Skin assortment
-Net Framework 3.5
-Htc Ringtones added
-HTC Performance
-Oxis Memory
-HTC Smart Dialer
-BlueFrog Bigbutton dialer
-SMMS Picture mail ( fix for sprint mms being block) Thank you someguy
-ie res
-Ie Warning Screens Turned off
-Scroll Thickness Set to 9
No SMS sent Notification popups
-Battery Performance enhanced
-B2A2DP Tweaks
-hided data Connection Bubble
-Skinny Signal Bars added
-HTC sliding sounds
-Startclean
-Autoupdate for wm6.1 applied
-SqlCeMobile 3.5
-quickmenu
-Advanced Config added
-Microsoft Voice Commanded
-nueEXt Rom Config
-nueAudio
-NueFont
-NueLED Driver Control
-Font set to calibri
-TouchFlo
-1cal calculator
-i-nigma bar code reader
Download SPRINT VERSION with smms built in:
BACKUP MIRROR:
ALLTEL VERSION DOWNLOAD:9minus smms for sprint users)
Know Issues Remove Battery After Flash For 1 minute....After Hardreset to accomodate for new page pool of 6mb
THEME CHANGE FIX. VERY SIMPLE REG EDIT
hklm\security\policies\policies\00001007 change hex value to 28
BASED OFF OF RADIO 3.42.30
Taken from the new official Vogue Ship Rom and ported to the Titan.
Flash with USB using the executable here:
http://rapidshare.com/files/12551852...42.30.exe.html
or
Flash from Storage Card using TITAIMG.nbh here:
http://rapidshare.com/files/12505222...42.30.rar.html
I take no responsibility if you mess up your phone.
most of all if you like my work please donate. Even a buck helps towards a new hard drive so i can store more programs for fellow junkie.... Keep the revolution alive....
Take 3 Hybrid
pics in this order
patch certmod
update drivers
switch to 19208
disable ipv6
nuefirstbootagent
nuelinks
nuepackageinstaller
nueprovxmlloader
pim backup readded
-Clean
-NETCF3.5/SQLCE3.5
-3.xx Series ROM
-GPS
-multicarrier
-AdobeReaderLE
-Office Excel
-Office PowerPoint
_Office Word
-One Note
-Net Framework 3.5
-HTC Performance
-Oxis Memory
-HTC Smart Dialer
-ie res
-B2A2DP Tweaks
-HTC sliding sounds
-Startclean
-SqlCeMobile 3.5
-quickmenu
-nueEXt Rom Config
-nueAudio
-NueFont
-TouchFlo
-1cal calculator
http://rapidshare.com/files/133940282/Take_3_Hybread_Sprint_edition.exe
http://rapidshare.com/files/133934922/Take_3_Hybread_Sprint_edition.exe
http://rapidshare.com/files/134662517/Take_3_Hybread_Alltel_edition.exe
or
