[SKN] Pink theme With Modded Clock For Touchflo2D
....................Ultimate NOOB Guide CLICK HERE....................
....................PPC Guide For Dummies CLICK HERE....................
....................Dont Know How To Flash A ROM? CLICK HERE..................
....................Learn To Search CLICK HERE....................
Re: [SKN] Pink theme With Modded Clock For Touchflo2D
This is a skin only. You have to have Touchflo 2D installed already. If already installed, then just drop the files into the Windows folder and say yes to the files it wants to replace, then soft reset, and "you're golden."Comment
................I do try at least, and I am trying to learn, it's just nice when you have men who know more to do it for you.......hahahahaha!!!
hahahhahahaha you know i have to do it lmao : > im D/\SHY you know hahahahComment
hello i have touchflo 2d installed already on my htc mogul and i love it but i want to change the colors and the clock is this possible? i just download the pink theme/skin and transferred the files to my phone but nothing happened i cant find it anywhere in the phone to switch colors/clocks. can some one help please thanks.Comment
You need the customizer here https://www.smartphonejunkie.org/sho...lla+customizer or
Got a ? Use The Help Desk Here
Need it all in one thread?Click Here
Learn How To Flash A Rom?Click Here
Are You New To The Scene?Click Here
Need to Learn How To Search? Click Here
The End All, Be All of Noob Guides.Click Here
Make Sure You Hit The Thanks And/Or Installed Buttons If Someone Helps You Or You Use There Programs!!!
Is it possible to have different clocks themes/skins/colors on your phone and just choose the different one you would like to use?
--------- New Post Merged on 11/2/2009 at 1153 --------
i tried it but i still cant get the pink theme to show up. It there a way that i can turn off my current clock that is running and turn on the pink theme/skin?Comment
You have to make your windows folder visible to see it through activsync. Or you can use a app like total commander to just do it all on your phone. But it has to overwrite the original windows files or it will never work.Got a ? Use The Help Desk Here
