PROBEX-ALIEN-X suite for touchflow2d
  • asiandrg0n
    • May 22
    • 673
    • Mogul
    Well here it is guys the moment you you will remember.... like when Elvis died, or the world trade center got smoked... the first time you got laid.... ok ok maybe Ive gone to far... lol The FULLY SKINNED PPC INTERFACE
    for touchflow2D equipt devices is here.
    There are instructions in each of the folders inside the .zip file to install each part of the theme
    I wish I new how to create cab file installs for this as it is a bit of a job to do everything but... hey
    I'm only good a few things not EVERYTHING.... maybe someone will create cabs for this or maybe they won't
    Anyway if you follow the instructions you will be fine.
    Enjoy another fine PROBE-X-DESIGN for Smartphonejunkie.com
    Keep me motivated... comments or donations are very welcome.
    +++UPDATED++++
    I have created .cab files for most of the install process but you will need to follow the instructions and install the cabs in the proper order.
    also you will need to download the S2U2 .zip separately and install it to your S2U2 gfx folder location [be sure to delete the entire gfx folder in your S2U2 directory first]
    and you will need to download the ALIEN-X.tsk file and put it into the my documents folder of your ppc then set it as your theme
    and last download the background image upload it to your phone and set that as your background by going to touchflow settings background image.
    Whew even in cab files its a big job lol
    +++Update ended++++
    +++Update Oct 1st+++
    IF YOU ARE RUNNING A ROM WITH TOUCHFLOW BUILT IN OR ANY UPDATE FROM AND INCLUDING #15 up YOU MAY HAVE ISSUES WITH THIS THEME
    as well as any theme out there. If you wish to use this theme problem free with everything working properly use a rom without touchflow built in and
    use the update number #14 files from XDA and everything will work problem free
    ALSO IF YOUR NOT USEING A HTC TOUCH dont use the cab install files as they include the dialer for the touch this may [probably] cause you issues on other phone
    use the step by step guide in my .zip file and skip the phone dialer folder.
    +++UPDATE ENDED+++
    I have tested on multiple roms without touchflow built in currently on OMJ's 3.09 custom and 2 different touchs with this procedure - Update 14 step by step install files from XDA
    My skin step by step install files no issues at all everything working smooth.
    Also I have installed my newest unreleased contest skin via .cab install over the alienware one and everything agian went smoothly I upgraded to XDA install 16 everything crashed so hard reset and went back to the old #14 version agian no issues.
    Update..........................................No v 15
    Used the latest Jade touchflow build #20 and theme manager
    and also made a new clock and some overall improvements
    No issues
    Updated Images: GO HERE
    ADDED SCREENSHOT OF THE VERSION 20 With the updated clock.
    Running one of my themes??? add this to your signature. I will host the image.
    http://probex.ca/SPJ/PXD.png
    Thanks for your support.
  • elboriyorker
    OG Member
    • Nov 08
    • 9318
    • Metro
    Re: PROBEX-ALIEN-X suite for touchflow2d
    thank you probey no more echooooooooooooooooo lol..weird stuff bro
    SPJ Bulletin @
    www.smartphonejunkie.org
    • broSki
      Old Timer/Snr Member
      • Feb 12
      • 1562
      • Sprint Pro
      • 2963 DL speed REV A
      hahah i took a look at the old post...i was cracking up on the floor dying...well about the theme....Proby the theme is insanely hot and nice....i luve the start icon and s2u2 and everything blends so well, now one thing is, after installin everything, when I go to sms it turns off tf2d where it says tap to start touchflo 2d.....i tried installin another skin and the issue was fixed, I also installed the 1st version and tried the updated(cabs) and still a no go.....I hard reset and still nothin, hmmm im wondering lol
      NOOB SECTION CLICK HERE
      LEARN HOW TO SEARCH CLICK HERE
      LEARN HOW TO FLASH ROMS CLICK HERE
      Sprint Speed:
      • elboriyorker
        OG Member
        • Nov 08
        • 9318
        • Metro
        hahaha i found the problem resolved now..
        SPJ Bulletin @
        • asiandrg0n
          • May 22
          • 673
          • Mogul
          Can anyone else confirm this problem? As I I tested and re-tested this many times over from a clean rom install just to see if any problems would arise? I'm usen update 14 of touchflow2d to base this off of. If others are having this problem I will have to go back and try agian... the problem your describing was caused by the main page icons [the tiny ones] originally this problem was holding me back from skinning the entire suite but as far as I knew I had fixed this problem...I will have a look thro my uploaded files and be sure I didnt put up the old image....
          • asiandrg0n
            • May 22
            • 673
            • Mogul
            everything looks correct??? Please if you have this installed let me know if everyhting is working for you...
            • meansixx
              SPJ Junkie
              • Jun 13
              • 418
              • Touch Pro 2
              im still having trouble getting this extracted, is there any way u can host it like on rapidshare to see if that would help? sorry for all the troubles...
              i got the s2u2 and the tsk to extract but not the actual tf2d files or the cab files
              • asiandrg0n
                • May 22
                • 673
                • Mogul
                http://probex.ca/sigs/ALIEN-X-SUITE-by-PROBEX.zip
                here I put them on my server try that.
                • elboriyorker
                  OG Member
                  • Nov 08
                  • 9318
                  • Metro
                  i checked the zip and i can open and extract file don't know whats up
                  SPJ Bulletin @
                  • broSki
                    • Feb 12
                    • 1562
                    • Sprint Pro
                    yea the attachments work fine
                    Sprint Speed:
                    • meansixx
                      SPJ Junkie
                      • Jun 13
                      • 418
                      • Touch Pro 2
                      hell yeah, thanks homie. idk what was going on but i got it to extract from ur server.
                      -----Added 24/9/2008 at 02 : 07 : 26-----
                      finally got everything set up, very sweet set up, thanks alot pro
                      Last edited by meansixx; September 24, 2008, 02:07 AM. Reason: Automerged Doublepost
                      • MikeyD
                        Find Em Hot Leave Em Wet
                        • Apr 25
                        • 1609
                        • TP2, omnia, Mogul
                        • Can You Hear Me Now
                        #12
                        Originally posted by Sh0wNuF
                        first off, probex this is sick..instructions were perfect and everything works and looks smooth as hell good stuff bro...as to the mms shutting down tf2D it hasn't done that so far, i think the problem is with the actual touchflo2D as it would not only shut down itself but any program i was running at the time.
                        bro whats with all the posts. you only need to hit the button once
                        Can't Access Something Click Here
                        Can't Find Something Click Here
                        Need Help, Check Out the Help Desk Click Here
                        IF SOMEONE HELPS YOU HIT THE "THANKS" BUTTON
                        FOLLOW THE RULES
                        AND PLEASE CLICK INSTALL ON ALL APPS AND THEMES
                        PLEASE POST SOMETHING, ANYTHING HERE
                        • MikeyD
                          • Apr 25
                          • 1609
                          • TP2, omnia, Mogul
                          #13
                          sorry for the multiple post, my computer was doin sum wierd stuff, how can I delete the extra posts?
                          hey staff dont crusify this guy for his multiple posts read my thread in the staff room first, Labled: Heads Up
                          FOLLOW THE RULES
                          • MikeyD
                            • Apr 25
                            • 1609
                            • TP2, omnia, Mogul
                            #14
                            Originally posted by gullzway
                            Awesome theme! Am am having the same problem with the SMS page closing down touchflo though. Also haven't figured out why my top and bottom bars are gray and not black.
                            Edit: must be something going on with the server, I only hit submit once and my posts are also showing up multiple times?
                            I ll report it thanks
                            FOLLOW THE RULES
                            • meansixx
                              SPJ Junkie
                              • Jun 13
                              • 418
                              • Touch Pro 2
                              yeah, finally got everything set up and i too also havin the same problem. but mine actually shutting down when i hit the email for my yahoo.... thats the only problem that i had that touchflo shut down.
