Alienware Theme
  • Mike20PR
    SPJ Trend Setter ADMIN
    • Mar 31
    • 2453
    • Touch Pro 2
    Alienware Theme
    http://www.megaupload.com/?d=Y3PCFYAX
    Below is a CAB file for those who are having issues changing to .theme, just put to sd card and install to device. I also attatched a zip with three different backgrounds. Just save to my documents and in the settings tab choose wallpaper and you will see them in my documents. They all have a nice different look. Enjoy
    TAylorSPJ.
    ....................Ultimate NOOB Guide CLICK HERE....................
    ....................PPC Guide For Dummies CLICK HERE....................
    ....................Dont Know How To Flash A ROM? CLICK HERE..................
    ....................Learn To Search CLICK HERE....................
    Re: Alienware Theme
    could someone please attach this.... at work and cant download unfortunately :>
    • raybond25
      • Sep 15
      Re: Alienware Theme
      i got you dash...here ya go bro
        Re: Alienware Theme
        thanks buddy donwloading now :>
        • ArtSolis1990
          • Oct 06
          • 6
          • touch
          Re: Alienware Theme
          hey nice theme i was wondering if u could help me with it i downloaded it and i cant get it to work for me. so maybe if u could send me a message with a step by step on what to do to get it to look like that. bc i think thats pimpin
          good work man
          • raybond25
            • Sep 15
            Re: Alienware Theme
            good work man
            your profile says that you have a ppc 6800, if thats true then you cant use this theme bc its for touchflo3d meaning vga (diamond or touch pro) you need to look in the touchflo2d theme section if you want themes for touchflo2d (you have to have the app first)
            • dinfamouspoet
              • Oct 06
              • 1
              • HTC Touch 6900
              Re: Alienware Theme
              does this theme work on 6900?
              • raybond25
                • Sep 15
                Re: Alienware Theme
                no as i said in the post above yours, this is for VGA devices (htc touch diamond, htc touch pro) only, you can get something like this by installing touchflo2d on your device https://www.smartphonejunkie.org/sho...ght=touchflo2d, then i can recommend probex's alienware theme for touchflo2d found here
                • RconR007
                  • Jun 09
                  • 11
                  • Mogul
                  Re: Alienware Theme
                  Hi Everyone:
                  New to the TOUCH DIAMOND (I just got it). I was wondering if anyone could explain how to install these cool themes you guys are making on it.
                  Thanks everyone,
                  RconR007
                    Re: Alienware Theme
                    Originally posted by RconR007
                    Hi Everyone:
                    Thanks everyone,
                    RconR007
                    as asked and mentioned before... you neeed the touchflo config the one Dash posted.... then you drag the theme to your phone run the app from the phone. just the files, soft reset, and done!
                      Re: Alienware Theme
                      hey question for you guys.... look at the files enclosed in this theme..... anyone notice anything wrong????? there isnt nearly enough of them..... i think that this may be a 2d theme......... not even enough to cover half of images.........
                      • sitaniace
                        • Oct 22
                        • 2
                        • blackberry pearl
                        • alltel
                        #12
                        Re: Alienware Theme
                        how do i instal this on my htc,please reply
                          Re: Alienware Theme
                          look at the post above mine which is above yours...... and also this will not work on your phone..... it will only work for the diamond or touch pro
                          • rich7781
                            • Jan 10
                            • 1817
                            • Tilt
                            #14
                            Re: Alienware Theme
                            did we figure out if this is for 3d or what? i installed in my sd and used diamond touchflo3d config i see the folder but thats about it..wont apply....anyone?
                            • BeauTful
                              • Aug 15
                              • 832
                              • XV6900
                              • Verizon
                              #15
                              Re: Alienware Theme
                              Hey Kaos I tried it on the tp and couldn't get to work. I also put it on the TOuch with the 2-d and it worked
