Cab installed Themes
  • MrDude
    • Jul 14
    • 16
    • XV6900
    • Verizon
    Hey all - I just came accross some .cab installed Themes and thought I would share.
    This is only one of many that they offer.
    Check em out here!
  • rich7781
    • Jan 10
    • 1817
    • Tilt
    Re: Cab installed Themes
    these are for gsm version from the look of it..........
    • MrDude
      • Jul 14
      • 16
      • XV6900
      • Verizon
      So far I have installed one of these and it seems to work fine on the CDMA Sprint Touch Pro however you need to remember to uninstall it first if you want to load another theme with the .theme extention using the Diamond TF3D config. Otherwise you have a mix of the two themes. also looks like a very simple way to make a quick personalized theme. I have not tried yet but want to make my own theme so this might be a good way to start.
      • elboriyorker
        OG Member
        • Nov 08
        • 9328
        • Metro
        please post more info,image or something otherwise it will be canned. direct link to another site without general info is against forum policy.
        SPJ Bulletin @
        www.smartphonejunkie.org
        • MrDude
          • Jul 14
          • 16
          • XV6900
          • Verizon
          Sorry still new to the posting etiquette.
          Ok will try to post image here:
          • RRexA3
            • Nov 10
            • 1
            • wing
            • Unknown
            • tmobile
            I have a sprint Touch Pro however after I install nothing happens... I still have my Dirty Paper theme up =/
            --------- New Post Merged on 10/11/2008 at 0124 --------
            I have solved the issue. Apparently it doesn't respond well if you install from the storage card however I had no issues installing it from the device directory.
            • MrDude
              • Jul 14
              • 16
              • XV6900
              • Verizon
              Ahh - The way these .cab files install (from what I have read and from the one I installed) you need to disable TF3D in the Start--> Settings--> Today
              But first if you are running the Dirty Paper theme you would want to run the Diamond TF3D Config program and set the default theme back up THEN after your soft reset Disable the TF3D then run the .cab theme file. Reset then enable the TF3D again.
              When you want to change that out (I found out the hard way) you need to turn off the TF3D then uninstall that .cab file from the Start--> Settings--> System--> Remove Programs.
              --------- New Post Merged on 10/11/2008 at 0109 --------
              Glad you got it working - Yea with the .cab file install I would do it from your device directory and install it to the device. These are a bit different to install and dont seem as easy as the .theme files that install with the Diamond TF3D Config program. However if you want to mess with making your own theme I think this way would be a simple way to start.
              Last edited by Balastrea; November 10, 2008, 12:54 AM. Reason: Automerged Doublepost
              • Tizijones
                • Feb 04
                • 1
                • ppc 6700
                do u know where i can get other cab file themes. i have the hello kitty one. LOVE IT... thanks
                • Megzy
                  • Aug 20
                  • 1044
                  • htc 63cc
                  • BT
                  search the site, check out theme area especially, there are plenty... Taylorspj just post one not to long ago... cabbed themes seem to become more and more commen
                  --------- New Post Merged on 19/2/2009 at 0207 --------
                  It shouldnt matter if theyre GSM as theyre just TF3D themes... they should work on a pro or a diamond cdma or gsm or anyother TF3D install/port... I thought
                  Last edited by crazaytalent; February 19, 2009, 01:23 PM. Reason: Automerged Doublepost
                    thats correct it doesnt matter if they are gsm or cdma.
