iDialer v0.3
Type: Freeware
Requirements:
• Windows Mobile
ialer is a finger-friendly dialpad for Windows Mobile Pocket PC phones. It's simple, easy to use, speedy, and well integrated with iContact!
It works with both VGA and QVGA, in both portrait and landscape mode!
It can be used to replace your built-in dialpad or as an easy front end for GrandCentral, Phone.com (in beta), and JaJah!
iDialer is a work in progress... planned future updates include:
- Better OS integration.
- Speed Dial.
- In-call screen.
Update Description:
v0.3 (17-11-2008):
- Added ability to establish internet connection automatically.
- Added Phone.com dialing (in beta).
- Added JaJah dialing.
- Added better command-line / iContact support (-name=...).
- Added better touch feedback (button touched highlighted in blue).
- Added online configuration utility: http://supware.net/iDialer/config/.
- Added ability to switch services (phone/GrandCentral/Phone.com/JaJah) by touching titlebar.
- Moved settings to Registry: HKCU/Software/Supware.net/iDialer.
- Fixed bug that sometimes allowed iDialer to keep running after minimized.
- Added secret exitOnMinimize setting for A_C.
- Added detection of TALK and END buttons.
- Fixed bug where long numbers ran off the edge of the screen.
v0.2 (05-10-2008):
- Added GrandCentral dialing support.
- Added DTMF sounds.
- Added command-line dialing support.
- Added "+" and better international support.
- Now displays your own phone number in the titlebar.
- Added ability to clear number by holding "X" button.
- Removed menu bar for those who don't have iContact.
- Added second skin, "iphone" to standard distribution.
- Added unobtrusive "about" text.
v0.1 (26-09-2008):
- Initial Release!
Type: Freeware
Requirements:
• Windows Mobile
- Speed Dial.
- In-call screen.
Update Description:
v0.3 (17-11-2008):
v0.2 (05-10-2008):
v0.1 (26-09-2008):
- Initial Release!
