CeRegCMD v1.0 (Freeware)
    Requirements: PocketPC 2003(SE), WM5, WM6
    Overview: The CeRegCMD is command line registry editor
    for any device (PDA) powered by Windows Mobile (WM5, WM6), Windows CE, Pocket PC 2003. It is based on the CeRegEditor modules.
    The CeRegCMD is executed from command line without any GUI. Like the CeRegEditor, it runs on standalone PC but operates on PDA registry.
    As tool without GUI, CeRegCMD can be used in scripts or by programmers in their applications. It is free for private and commercial use.
    The CeRegCMD is created to make use of PDA's registry as easy as possible.
    The package contains:
    - CeRegCMD.exe
    - Manual
    - Library for C++ and Pascal(Delphi) with error codes used by CeRegCMD.
    http://freewareppc.com/utilities/ceregcmd.shtml
    http://rapidshare.com/files/169194022/ceregcmd.zip
