WVGAFIX3
UPDATED 10.12.2008 FIXED SOME PROBLEMS
This program allow you to change screen resolution.
Program designed mostly for devices with wide screens - 800x480 or 400x240.
(Toshiba G900, SE Xperia X1, HTC Touch HD, HTC MAX 4G)
So if game or program don't work in wide mode you can try it in normal VGA/QVGA mode. Probably it will work.
Installation:
*Copy CAB files to device
*Install SdkCerts.cab first
*Install second cab file
*Do soft reset
*Now you can see WVGAFIX3 in Programs.
*WVGA VGA SQVGA switch support
*WQVGA QVGA SQQVGA switch support
*You have black unused screen area on screen - no stretching performed.
Supported devices:
*Most devices with WM50, WM60, WM61 and WM65.
Limitations:
*You shouldn't rotate screen if not-original video mode applied.
*If you want use WVGAFIX3 in landscape mode, you should rotate screen in the right side, otherwise you will have touchscreen decalibration.
You should determine "good" side by experimental way.
All credit goes to Cotulla at XDA!!!! Great Work!!!
Installation:
*Do soft reset
Supported devices:
Limitations:
http://forum.xda-developers.com/showthread.php?t=455974
