Superman Potrait and Landscape
  • Superman369
    • Sep 22
    • 2084
    • Touch Prizo!!!
    [NEW] Superman Potrait and Landscape
    Just unrar, copy the arrows, wallpaper and wallpaperL to your S2U2 gfx folder, delete the previous ones, soft reset and your good. This supports both portrait and landscape. Enjoy:)
    http://rapidshare.com/files/172879082/s2u2_superman.rar
    Optional: You can save the third picture attached, name it wallpaper, and transfer it according to the above instructions if you like it better then the default one provided.
    Hit that THANKS!!!
    Got a ? Use The Help Desk Here
    Need it all in one thread?Click Here
    Learn How To Flash A Rom?Click Here
    Are You New To The Scene?Click Here
    Need to Learn How To Search? Click Here
    The End All, Be All of Noob Guides.Click Here
    Make Sure You Hit The Thanks And/Or Installed Buttons If Someone Helps You Or You Use There Programs!!!
