sinPocketStopWatch v3.2 (Freeware)
    Requirements: PocketPC 2003(SE), WM5, WM6
    Overview: sinPocketStopWatch is a chronograph stopwatch application for Windows Mobile
    This is the tool which runs Anywhere Anytime!!
    There are four kinds of the display mode.
    *Normal-Mode
    Display for hour,minute,second.
    It is possible to use suspension among them.
    *High-Precision-Mode
    It is possible to display until a maximum of 1/100 seconds.
    (It is controlled not to enter a suspension mode.)
    And using chronograph to be occupied blinks.
    *Decimal-Minute-Mode(For industrial use)
    It can measure by 1/1000 minute units.
    *Decimal-Hour-Mode(For industrial use)
    It can measure by 1/100000 hour units.
    In the log screen, the log and the result of analysis which was calculated from the log in the measurement time are displayed.
    1.The minute log with time, lap time, totaled time every measurement with once 2.The display of the average lap time, the best lap time, the minimum lap time, the totaled time which was analyzed from the log
    In the option screen, it is possible to change the mode which appears at the time of start, sound settings and lock the buttons to prevent wrong operation.
    http://www.freewarepocketpc.net/ppc-download-sinpocketstopwatch.html
    http://www.megaupload.com/?d=J70K05EE
    < CAB file: sinpocketstopwatch_320.cab
