Touch Pro (Raphael) HSPL Unlocker And Relocker (CDMA ONLY)
  • elboriyorker
    OG Member
    • Nov 08
    • 9328
    • Metro
    CDMA Raphael Elite Team (see: https://forum.ppcgeeks.com/showthread.php?t=41345) presents exclusive Touch Pro CDMA Hard-SPL to you!
    SSPL, HSPL, relocker made by cmonex, Wrappers by olinex, SD flasher and relocker (coming soon) by no2chem. thanks to NexVision (btw I'm really sorry), zule/Shadowmite and no2chem for testing!!!
    there are again two HSPL's (similar scene to Diamond_C).
    1. 0.25.MFG for the hackers, because otherwise, it is too old, apparently has splashscreen issues and only 128MB ram. but it has mw, it has rtask, etc. etc. ;)
    2. 0.37 for other people, this has no screen issues but no MFG commands.
    (the SSPL is based on the MFG but do not use it as such, only use it to get Hard-SPL on the device!)
    Instructions:
    first, if you have GSM Touch Pro/Raphael (NOT CDMA, NOT SPRINT/VERIZON/ALLTEL/TELUS), this will brick your device.
    to download a compatible hardspl package for gsm touch pro you can go to forum.xda-developers.com.
    but if you have CDMA Touch Pro/Raphael (SPRINT etc - see note below!!), then you have to use this hardspl, not the one at xda-developers!!!
    NOTE: tested on Sprint touch pro so far, we would like to test Verizon etc touch pro's when they come out.
    ok, now the instructions themselves.
    0a) make sure you have .NET framework installed on your PC! if not, get it from https://www.microsoft.com/downloads/d...DisplayLang=en
    0b) if you have vista, WMDC update is recommended: https://www.microsoft.com/windowsmob...ce-center.mspx
    1) download Hard-SPL package from attachment, extract to an empty folder.
    2) it is recommended you download only the Raphael_CDMA_HSPL_037.zip unless you want to tinker with MFG SPL.
    3) you must Have Phone Synced with PC in Windows Mobile!
    4) run Raphael_CDMA_HSPL_037.exe (or maybe 025, if you want to experiment with MFG SPL),
    5) follow steps in the RUU, and check on the device for prompts after PC shows loading bar.
    6) it should go to tricolour screen now and say 0.25.C-SSPL.
    7) SPL flashes, device automatically reboots, job done.
    8 ) to confirm you got it installed, go into bootloader mode (tricolour screen!) and verify the screen shows 0.37.CMONEX (or 0.25.CMONEX MFG).
    NOTE: you will not see the SPL version during normal boot, that is the OS version, not SPL!
    to enter bootloader mode to see version: with the device turned on, press and hold the volume down button along with the power button, then press the reset button with the stylus tip, then release the volume down and power buttons when bootloader tricolour screen appears.
    NOTE 2: anyone having problems with the device entering SSPL automatically, please copy SSPLManual.exe from the SSPLManual.zip attachment to the device and run it. then once the screen is in SSPL, run RUU manually. i.e. you run the RUU on the PC, if it isn't obvious.
    NOTE 3: this is unsigned Hard-SPL. no limitations on flashing ROMs or radio packages. also, this has overwrite protection, if someone needs to revert to stock SPL for warranty reasons, a stock SPL downgrade package is also available here.
    NOTE 4: do not use this RUU to flash anything else! this is only intended for flashing the Hard-SPL.
    NOTE 5: use Relocker *only* if you need to return the phone for warranty. only use it as last step - after reflashing stock OS and radio.​
    SPJ Bulletin @
    www.smartphonejunkie.org
