Sprint Picture Mail (Issue Fixed)
  • rich7781
    • Jan 10
    • 1817
    • Tilt
    Ok so how many of you out there cant get sprints picture mail to work...guess what i found a way....you all most likely run frame work 3.5 for all your goodies...well sprints pic mail hate 3.5..its based of of 2.0....so install both frame works.....
    install this....
    download:
    http://rapidshare.com/files/201046760/netcfcfg.cab
    now this has a 'Device Policy' tab allows you to set which version of dotnet to use by default.
    The 'Application Policy' tab allows you to set which version of dotnet to use for a particular application.
    I set the device policy tab to use 3.5 and put the picture mail app in the application policy tab to run with 2.0. its located in windows/picturemail.exe type it in just like that
    now after this.....
    1. go to epst ##3282# and edit/restore. soft reset. (you will need your mrl)Then Soft Reset
    2.Go to Start/settings/update profile. soft reset.
    it should be working now....tested and confirmed with my fiances Verizon phone...sent 20 pics all went through in under a minute...sent them back to me...got them back in same amount of time....
    REMEMBER TO PRESS INSTALL AND THE THANK YOU BUTTON........
    tested on touch pro
    edit here is links to 2.0 as well as 3.5 frame works....
    http://www.microsoft.com/downloads/details.aspx?familyid=9655156b-356b-4a2c-857c-e62f50ae9a55&displaylang=en
    DOWNLOAD 3.5
    http://www.microsoft.com/Downloads/details.aspx?familyid=E3821449-3C6B-42F1-9FD9-0041345B3385&displaylang=en
    Here is even the picture mail app.
    http://rapidshare.com/files/201175256/PictureMail_0.2.2.3.CAB
    oh here is the mrl grabber if anyone needs it..
    http://rapidshare.com/files/201213363/BAFMSL.cab
    big ups to baf for it...
    EDIT
    adding profile and prl update cab..some custom roms seem to be missing this important key to getting pic mail to work right.......
    DOWNLOAD
    http://rapidshare.com/files/201221258/Sprint_Update_Profile___PRL.cab
  • chauleyb
    • Feb 19
    • 129
    • touch pro
    Re: Sprint Picture Mail (Issue Fixed)
    i was wanderin where can i find netframe 2.0 i looked around but cannot find here i googled it but dead end keep gettin netframe 3.5 which i have already thanx in advance
    --------- New Post Merged on 22/2/2009 at 0614 --------
    ok guys nevermind on the netframe 2.0 i found it and installed it but when i enter the ##3282# it asks for an unlock code how do i retain the unlock code and mrl thanx in advance
    Last edited by chauleyb; February 22, 2009, 06:57 AM. Reason: Automerged Doublepost
    • rich7781
      • Jan 10
      • 1817
      • Tilt
      i don't think this will work for you..its more for pro and diamond for the picture mail...you can try it though...its posted in the 6800 help desk for a msid and mrl grabber.
      • malden1
        • Jun 30
        • 803
        • mogul
        Thanks alot for this bro because that dumb app never seemed to work right
        • rich7781
          • Jan 10
          • 1817
          • Tilt
          it should work perfect now...ive been testing since yesterday..works flawless for me now..
          • malden1
            • Jun 30
            • 803
            • mogul
            Cool and i downloaded that 2.0 file and its in like a msi format what am i suppose to do with it and im such a NOOB!
            • rich7781
              • Jan 10
              • 1817
              • Tilt
              plug your phone into pc...connect through activesync device center what ever you got..and run... it installs through there...
              side note....walking big jew through this noticed some customs dont have prl and profile update...so i added cab for it in first post....
              • gogorob
                • Jun 12
                • 825
                • AT@T Tilt
                • T-Mobile
                Thnksalot hopefully this will fixed my promblem, theyve been sending pics thru sprint pic mail and never recieve anything probably will recieve them 3 0r 4 hrs later thnxs KAOS appreciate all your help..peace
                • rich7781
                  • Jan 10
                  • 1817
                  • Tilt
                  it should did on my end...it takes patience to do...so far i got jew able to send now...working on the receiving issue...but i think a re provision will cure that...
                  • chauleyb
                    • Feb 19
                    • 129
                    • touch pro
                    sry bout that kaos forgot to update but i do have the pro cud u help me out with my problem need my mrl and how do i figure out my unlock code
                      as it says in the first post you need to download the msl grabber that he linked you to. and so far so good thanks kaos!!
                      • chauleyb
                        • Feb 19
                        • 129
                        • touch pro
                        gotcha sry bout that i seen but was reading to fast thinkin it was only for the mogul thanx
                        • rich7781
                          • Jan 10
                          • 1817
                          • Tilt
                          #13
                          glad to hear it....same here...jew seems to be the only one having issues....he can now send but hes not getting them...could be network in his area....lets hope he doesn't give up..
                          • PHE-NOM
                            Creativity Unleashed
                            • Oct 14
                            • 1494
                            • htc pro2 baby!!!!!!
                            #14
                            thanks for the find bro
                            NEW TO SPJ? CLICK HERE
                            NEED TO LEARN HOW TO FLASH? CLICK HERE
                            QUIERES SABER COMO DESBLOQUEAR Y FLASHAR TU TELEFONO? PRESIONA AQUI
                            TIENES PREGUNTAS SOBRE APPLICACIONES O TEMAS, PERO NO SABES HABLAR INGLES? PRESIONA AQUI
                            • rich7781
                              • Jan 10
                              • 1817
                              • Tilt
                              #15
                              no problem remember to hit install....like i said its working flawless for me now....
