[CAB]HTC Rhodium Menu Enhancement-Replacement[3/10/09]
  • Mike20PR
    SPJ Trend Setter ADMIN
    • Mar 31
    • 2453
    • Touch Pro 2
    i found a fix for the 2100 build issue, just replace the gwes.exe from your build to the updated build one so no rom hunting to have this working... attached is the files needed to be replaced for this to work
    All Credit goes to Dharvey for the port
    http://forum.xda-developers.com/showthread.php?t=491457
    Thanks to btxakita, This is NOW release quality software!! This may look like fingermenu but it is actually created by HTC and is smoother, faster, and nicer looking than fingermenu.
    NOTES:
    1. You must have a 21000 OR HIGHER build on your device in order for this menu extension to work. Do not attempt to install this on any older builds because it won't work.
    2. jlavoie tested this on his beta WM6.5 device build 21159 and reports that this does not work with WM6.5. As of right now this is WM6.1 only.
    Installation instructions:
    1. Install cab
    2. Soft-reset
    3. Enjoy
    ....................Ultimate NOOB Guide CLICK HERE....................
    ....................PPC Guide For Dummies CLICK HERE....................
    ....................Dont Know How To Flash A ROM? CLICK HERE..................
    ....................Learn To Search CLICK HERE....................
  • OgReNaToR
    Member
    • Aug 22
    • 63
    • HTC Tilt
    • AT&T
    Re: [CAB]HTC Rhodium Menu Enhancement-Replacement[3/10/09]
    looks good.....vga only im guessing?
    • Mike20PR
      • Mar 31
      • 2453
      • Touch Pro 2
      yes, wvga resized to vga but keep tabs on the original link i placed in the first post. theres bound to be a qvga version soon
      • Mike20PR
        • Mar 31
        • 2453
        • Touch Pro 2
        • misfitspl9
          • Jul 17
          • 7
          • HTC Touch
          • Verizon
          will the replacing the gwes.exe fix work on a stock tp vzw rom? just dont wanna overwrite anything im not suppose to.
          thanks
            thanks
            dont know since i dont have a verizon device.... just back the original up on your card in case it doesnt work so you can revert back to that if needed.
            • Mike20PR
              • Mar 31
              • 2453
              • Touch Pro 2
              what he said, i did this on my old sprint touch pro with mightyrom and it worked
