nueLight v3 (freeware)
Requirements: PPC WM5, WM6 - mostly for HTC devices, others have to try , .NET
Overview: nueLight turns your HTC device with flash into a versatile flashlight. nueLight uses the flash LED for the camera and can even enter high-beam mode. nueLight also has a morse code function where it will send text you type as morse code over the flash LED. To use the locking mode, let go of the app button (default: voice command) and quickly tap the lock button (default: comm manager).
I’ve been experimenting with new UI interfaces, the latest engine and API I’ve developed aims on blending in with Manila. You can see it in the new beta of nueLight3, which aims to replicate the look and feel of the HTC CommManager – It supports both orientations and uses the same style resources as the HTC comm manager, allowing easy porting of existing skins – it now also has the advantage of being able to use the same resources under multiple resolutions (automatic stretching). Hopefully this allows Windows Mobile to be a little more attractive in the future…. you can download a preview version here (note only the CAB is available right now). As usual, please avoid direct linking and mirroring. It uses the HTCCamera1.dll interface now, so it should be compatible with all HTC devices with flash. In addition, the morse code transmit rates are now calculated automatically based on desired WPM, using the (dit_time = 1200/WPM) “PARIS” method.
