iContact v0.93 (Freeware)
Requirements: Windows Mobile Pocket PC 5 / 6
Overview: iContact is a simple contacts applications for your Windows Mobile device which will help you scroll your contact list in iPhone style by sliding down your finger in the screen!
iContact is a simple contacts applications for your Windows Mobile device which will help you scroll your contact list in iPhone style by sliding down your finger in the screen! It's really amazing and if you get used to it iContact could be one of your everyday apps.
The app is very basic, it only lists contacts in scrollable list. Use it for accessing your contacts by scrolling the list with fingers, similar to iPhone. Just tap, drag and release.
To select a contact, just tap and release, and standard contact details dialog should appear.
What's new in Supware iContact 0.93:
· Sped up recent list load time by 60 TIMES!
· Added error message for missing skin
· Added "gravity" setting to registry (accepts values from -100 to 100)
· Fixed screen flicker on long press
· Gave title bar battery better resolution
· Updated icon with VGA to match default skin
· Updated Favorite Category setting to display all categories, not just in-use
· Made iContact detect new skin/language installation
· Restored ability to scroll down from bottom of list and up from top of list
What's new in Supware iContact 0.94
· [+] Added scrollbar
· [+] Added "-details [oid]" command line option to jump straight to contact details
· [+] Added "Create Shortcut" button to create start menu item
· [+] Added "enableSensor" registry setting for touch sensor
· [+] Reset Missed Call Count upon visiting -recents tab
· [+] Added ability to jump to a letter using hardware keyboard
· [#] Fixed bug with D-Pad + SMS
· [#] Fixed clipping issue with contact names on QVGA screens
· [#] Fixed bug that was forcing exit when service changed
· [#] Used DeviceResolutionAware.h
· [#] Fixed bug with keyboard popup on categories or details
· [#] Fixed bug with Settings.exe not displaying more than 8 categories
Here's the full list of improvements:095
[+] Added "Remove Shortcut" button to details screen if appropriate
[+] Added "createshortcut" and "removeshortcut" to language file
[+] Added contact shortcut icons to start menu shortcuts for Windows Mobile 6.5
[+] Added ability for hardware "*" key to favorite/defavorite a contact
[#] Fixed outgoing calls to numbers with no name displaying [null]
[#] Hid SIP button being displayed by iContactAE
grtz cyber weesje
Administratot@spj hit thanks on the way out
