PowerArchiver 2010 Professional 115040 Beta 3
    [RELEASE] PowerArchiver 2010 Professional 115040 Beta 3
    PowerArchiver 2010 - universal archiver with support of all popular formats. This archive supports ZIP, RAR, 7-ZIP, CAB, LHA (LZH), TAR,TAR.GZ, TAR.BZ2, BH, ARJ, ARC, ACE, ZOO, GZ, BZIP2, XXE, MIME, UUE, XPI , EAR, WAR, REP, JAR, BK, QWK, Quake PK3, skins WinAMP, self-extracting executable file format ZIP and CAB, as well as CD-images: ISO, BIN, IMG and NRG. At the time the program is free, but as the expansion of its capabilities, has moved into the commercial status that, if we look at the overall trend, it is not surprising. This current application, which combines support practically all popular archival formats. If necessary, you can use encrypted archives using AES algorithm with varying degrees of stability (128-bit/192-bit/256-bit). The interface supports the change of skin, works as in classical or contemporary form.
    - Complete built-in support for 7-ZIP, ZIP, CAB, LHA (LZH), TAR, TAR.GZ, TAR.BZ2, BH, RAR, ARJ, ARC, ACE, ZOO, GZ, and BZIP2 file formats
    - Support for reading and extracting disc image formats: ISO, BIN, IMG and NRG
    - Built-in support for XXE, UUE, and yENC encoded files and full MIME (Base 64) support
    - Creating ZIP and CAB and PAE encrypted self-extracting archives using a Wizard interface
    - Support for unlimited size ZIP archives, with improved performance when working with 100,000+ files
    - Support for Deflate64, providing improved compression results (both size and speed)
    - Complete support for PKZIP 4.0 and PKZIP 4.5 disk spanning
    - Compression Profiles to store frequently used compression settings
    - Full support for ZIP AES encryption, 128-bit/192-bit/256-bit (supports: PKZip 5.1 (full), Secure Zip 8.0 and WinZip 9.0 AE-1 & AE-2) and proprietary PAE format using 5 different methods: Blowfish (128-bit), DES (64-bit), Triple DES (128-bit), AES 128-bit, and AES 256-bit
    - Support for AES encrypted 7-Zip archives and multivolume 7-Zip archives
    - Uploading archives or backups directly to FTP or SFTP (SSH) sites with multiple profiles supported and timeout option
    - Password manager for saving frequently used passwords
    - Tool for creating PBS backup scripts and running automated backups
    - Internal viewer that supports TXT, RTF, GIF, PNG, BMP, ICO, TIFF, GFI, SGI, EMF, WMF, PPM, Adobe Photoshop, Autodesk, Truevision, - ZSoft Paintbrush, Kodak Photo-CD, JASC PaintShop Pro, and Dr. Halo file formats
    - Many powerful archive operations (including: renaming files in archive, spanning archives, testing archives, viewing and writing comments, installing archives, and checking archives for viruses)
    - Drag and Drop from/to Windows Explorer and the Desktop
    - Two ways of viewing archives (Classic - all files in the same listing; Explorer - browsing through an archive like folders in Windows Explorer)
    - Complete integration with Windows (extracting archives and creating archives directly from Windows Explorer using powerful "Explorer Shell Extensions")
    - Ability to edit files within an archive using one single operation
    - Printing file listing to text file or HTML document
    - Tool for repairing corrupted ZIP archives
    - Converting between file formats (for example: changing a ZIP archive to CAB archive, or LHA archive to ZIP archive)
    - Extracting multiple archives at the same time
    - Batch Zip function to create multiple different archives at once
    - Favorite Folders to quickly locate archives
    - Powerful Find function for searching within an archive
    - Auto Update to automatically download and install new versions of PowerArchiver
    - Powerful help in HTML and a tutorial with pictures for beginners
    - Full skinning support via PSF files - includes interface skins, toolbar skins, icons and customizable application settings
    - Customizable toolbar that can be docked to any side of the application or float independently
    - Windows XP Theme and ClearType support
    Changes in PowerArchiver 2010 Beta 3 [15/04/2009]:
    New Features:
    Brand new ZIP Engine:
    - Multicore deflate zip engine, almost 8x faster on i7 than single
    core systems.
    - Improved speed of zip compression and extraction on any occassion.
    - Support for LZMA, PPMd, BZIP2 and WAVPACK in ZIP, according to
    latest ZIP standards.
    Both write and read support, making PowerArchiver only application that supports
    Winzip 12 and earlier files, while providing faster and
    stronger compression (up to 8x) compared to WinZip 12.
    - Multicore LZMA engine for ZIP.
    - Support for Unicode in ZIP, both read and write. Implemented throughout
    application.
    - Faster loading of archives with thousands of files.
    Windows 7:
    - Full Windows 7 support with jump lists, taskbar progress and taskbar
    icon overlays.
    - First application with new DirectSkin 6.0 engine that supports
    Windows 7 (32bit).
