Raise Data Recovery for Mobile 4.0 retail english v4
Requirements: Pocket PC with WM 2003 SE, 5.0, 6.0, 6.1
Overview: The Raise Data Recovery for Mobile product is intended for self-service data recovery of lost information directly from you Windows Mobile based PocketPC or Smartphone device. The Raise Data Recovery for Mobile product is intended for self-service data recovery of lost information directly from you Windows Mobile based PocketPC or Smartphone device.
Now, there are no need to worry about data deletion or loss in road or trip: with the Raise Data Recovery for Mobile product you may get your lost data back in minutes! Moreover, in case other your devices (e.g. photo camera, MP3 player etc.) have compatible removable flash card, you may recover easy your deleted photos, music, videos or documents as well as recover lost files due to device failure or storage format.
Based on Raise Data Recovery for FAT desktop product it provides you with power of desktop data recovery software on your pocket mobile device.
Available functions:
Deleted files recovery (undelete);
Recovery after storage format (reconstruction);
Recovery after file system damage (reconstruction);
Lost data recovery by type (IntelliRAW™).
Technical specifications:
Supported file systems: FAT, FAT32, Transact FAT and FAT32;
Supported storages: any compatible memory storage;
Trial limit: before registration software will not copy files above 64KB;
Storages limit: data recovery from main device memory storage is not available for most devices;
Product is based on desktop UFS Explorer Standard Recovery (Raise Data Recovery for FAT) product.
General Software use:
Download, install and run. The software must NOT be installed to storage you are going to recover data from. The software start shortcut is available under device 'Programs' menu group:
