EzInput 2.0 Compact QWERTY
    [RELEASE] EzInput 2.0 Compact QWERTY
    Compact QWERTY for EzInput 2.0
    UPDATE: I have a new fully-installable CAB file. I also found a way to add Compact QWERTY without destroying the Phone Keypad. So now, you should be able to use Full QWERTY, Compact QWERTY, and the Phone Keypad. This CAB also includes my improved landscape Full QWERTY layout, with bigger keys and a layout which mimics a traditional QWERTY keyboard.
    http://forum.xda-developers.com/show...2&postcount=24
    There is a new OEM based on this installation as well. I do have a slightly newer version of EzInput 2, but many of the images are embedded in a DLL. I will hack this soon enough and post that as well.
    Most of you are familiar with the EzInput 2.0 SIP that was taken from the Rhodium and ported to VGA devices such as the Diamond and Raphael.
    While the Full QWERTY keyboard of EzInput 2.0 is a major improvement over past versions, it is still difficult to type with without many errors unless you have small hands or type painstakingly slow. A notable omission of EzInput 2.0 was the Compact QWERTY included with EzInput 1.5. I was able to hack the Phone Keypad layout (XML / PNGs) and keyboard file (KBD) to create a Compact QWERTY version for EzInput 2.0 and am sharing it here.
    I wanted to get out a first release which is attached. For now this needs an install of EzInput 2.0 already on your device, but I will try to get out a full install shortly. I still need to edit the numbers and symbols layouts.
