QuotePad 202
    [FREEWARE] QuotePad 202
    QuotePad is a free notepad that will save the text selected on the screen without forgetting about its source.
    Quotepad saves the text selected on the screen without forgetting its source.Most information entered into your computer notepad is copied from somewhere. With Quotepad, you can do it with maximum efficiency: just select some text in any application, press a couple of keys and the selected text will be saved to Quotepad together with the URL of the webpage it was copied from.And if you may need to enter something else, you will be amazed by the usability of QuotePad and by how it can store your notes in a compact and comfortable way.QuotePad runs under Windows 2000/XP/Vista and has a multilingual interface.You can download and use it absolutely free of charge.
