Don't manually install all your applications and settings after every new ROM flash!
Make flashing a breeze with...
SASHIMI AutoInstaller RAW Edition v.8.0
by bengalih
New to SASHIMI?
Watch these video tutorials to see how easy it is!
Older Archive Videos Here
Want to cook SASHIMI into your ROMS?
Now you can with SASHIMI Compliance (SC)! For more info check here.
SASHIMI FAQ
What is SASHIMI?
SASHIMI is first and foremost an installer. Its main function is to install CAB, .REG., .XML, .EXE, and .MSCR files that can be used when setting up your device. It can be run in Manual Mode, Automated Mode, or in Manual+Auto mode. SASHIMI can also perform backups of your important files and registry entries and allow for easy restore during installation. It would be impossible to describe all the additional things that SASHIMI can do....well actually, not impossible, just lengthy...so read the documentation or check out the series of video tutorials!
Why SASHIMI?
You don't really think I came up with that unwieldy name first do you? SASHIMI, like all great things, is RAW! RAW, like sushi, sashimi means "uncooked". A RAW installer is most suitable for use on uncooked, stock, or lite ROMs. It helps users who would prefer to install all of their own apps an easy semi-automated way to do it. Of course it can be be used on cooked ROMs too, we sushi chefs like to share! Arigato! SASHIMI builds on the feature set of it's predecessors and the VIP+bengalih RAW Auto Installer, but with more wasabi-infused features!
What devices will SASHIMI work on and is tied to a specific region/language?
SASHIMI was designed for the HTC Kaiser and its variants. However it should work on most devices running Windows Mobile 6\6.1 with most standard resolutions. SASHIMI is also coded to support most ROM languages. Some of SASHIMI's special features (like the Auto Install to Storage Card) may not function on devices with unsupported resolutions or languages. For more detailed information see the sections on SUPPORTED RESOLUTIONS and SUPPORTED LANGUAGES in the documentation.
Can SASHIMI do this, that, and the other thing?
Yes. But seriously, read the documentation and go through the tutorial...you will be an expert afterwards. If there are features that SASHIMI doesn't have please post requests in the thread. If the requests sound good and I have the time to implement them, I will! Also, be sure to take a look at the available video tutorials for extra insight!
SASHIMI r0x0rz d00d, you r0x0rz, what can I do 4 U?
Gee thanks. I'm just happy people are using it. Just spread the word and leave feedback on what you like or what you don't. If you would like to make a contribution for all the hours I spent developing SASHIMI, you can do so here. 50% of all donations will go to charity.
You didn't answer my question here. This FAQ sucks.
Technically I shouldn't even put this in the FAQ, it's a statement, not a question. More accurately it's an insult. Why are you insulting me? If you read the documentation and still have questions, post in the forum and they will be answered.
CHANGE LOG AND FIXES
v.8.0 - 4/12/09
SEE DOCUMENTATION FOR FULL CHANGE LOG
CREDITS
Thanks go to:
Mirko Schenk - Author of MortScript, without which none of this would have been possible.
v3patel(VIP) - for his original VIP installer script which was a good portion of the inspiration for the original SASHIMI.
While it still bears some similarity to the VIP installer, it's grown well beyond and filled with tons of new features.
v3patel is also active in suggesting new ideas and offering some sample code to help make SASHIMI even better.
SKKV Software - For their SKTOOLS. The trial version is included in this package to assist with the custom registry exports, and full backups/restores. While the trial functions adequately for purposes of SASHIMI, you may want to check out full verisons of their software at http://www.s-k-tools.com/
DotFred - For his Task Manager application. This is what gives SASHIMI the power to import .REG and .XML files. The Task Manager program of course is so much more, and I urge you to try it out for all of its features.
Sleuth - for his work on UC which is integrated and included.
SASHIMI Users - To all of you who use the program and provide feedback and inspiration in the forums. Thanks!
SASHIMI Video Tutorials are here!
Download SASHIMI as well as full documentation with walkthrough below:
he has asked not to put it directly here but link to download.
Get it here:
by bengalih
New to SASHIMI?
SASHIMI FAQ
What is SASHIMI?
Why SASHIMI?
v.8.0 - 4/12/09
- NEW! - Added support for Touch HD and other 480x800 resolution devices.
- NEW! - Added support for Omnia and other 240x400 resolution devices.
- NEW! - Added support for 240x240 resolution devices.
- NEW! - Entirely new code routine to dynamically determine Storage Card/Internal Storage/Etc. has changed to support more device locations.
- NEW! - ASL - Alternate Storage Location (\CAB\ASL) directory allows for devices with multiple external storage locations to enable Auto install to both.
- NEW! - AUTO files have been completely rewritten to work with new SC/ASL detection routines. Much simpler format!
- NEW! - "Skip" directory (\CAB\Skip) allows for a temporary placement of files to be skipped during Auto Install.
- NEW! - Added Settings option to toggle automatic restart after Auto phase execution has completed.
- NEW! - Added Aggressive Auto Resume setting to modify behavior resulting from device reboots during Auto phase.
- NEW! - Added Settings option to toggle AUTORUN registry flag being set after a successful AUTORUN.
- NEW! - Added Settings option to manually reset AUTORUN registry flag.
- UPDATED! - Custom Links INI file generation now allows optional enumeration of subdirectories.
- UPDATED! - Management of alternate settings.ini files optimized.
- UPDATED! - Settings Menu structure reworked for streamlined organization of all settings.
- UPDATED! - Fixed minor issue where selecting a change for a missing directory on startup wasn't saving to INI file.
- UPDATED! - Fixed issue with PIM restore (restore pim.vol in lowercase (instead of PIM.VOL).
- UPDATED! - Fixed issue with some non-English languages giving errors because of missing "license" info.
- UPDATED! - Additional minor code optimizations.
- UPDATED! - MortScript to version 4.2.
- UPDATED! - Makisu to 1.9.2.
CREDITS
Thanks go to:
Get it here:
http://www.winmo-experts.com/viewtopic.php?f=7&t=4
