3herosoft DVD Cloner is an easy-to-use application created to help you copy
your DVD movies. It supports DVD 1:1 copy with a DVD burner, you can
easily get your DVD copies which remain 100% same to the original DVD
movie Discs. Moreover, it can compress DVD-9 (dual-layer DVD) to one DVD-5
disc.
3herosoft DVD Cloner also allows you to remove DVD menus, select subtitles
and audio tracks, or copy main movie separately to create customized DVD.
What's more, the DVD cloner can clone DVD with any region code. 3herosoft
DVD Cloner can not only clone DVD movie to ISO file or DVD folder, but also
burn ISO file and DVD folder back to DVD.
Here are some key features of "3herosoft DVD Cloner":
· Copy whole DVD disc including titles, menus,subtitles and audio tracks with
high quality;
· Support copying DVD-9 to DVD-9, copying DVD-5 to DVD-5 in 1:1 ratio;
· Copy whole DVD-9 movie to 8.5GB Dual Layer recordable media (DVD+R/RW,
DVD-R/RW) in 1:1 ratio;
· Compress DVD-9(Dual layer 8.5GB disc) movie and copy to one
DVD-5 (4.7GB) DVD-R/RW,DVD+R/RW with excellent quality;
· Save your favorite DVD movie Discs, and Prolongs the lifetime of your DVD-
ROM;
· Backup DVD movie to ISO file or DVD folder;
· Burn DVD from ISO file or DVD folder;
· High speed copying;
· Allows to remove DVD menus, select subtitles and audio tracks, or only
copy main movie to create customized DVD;
· Easy to use program that can backup your favorite DVD movie discs without
any learning curve;
· Support multiple languages including simplified Chinese and English;
· Support skin change;
