DKM Sudoku Sniper.v1.0 PPC cracked
Sudoku Sniper is an innovative variation of Sudoku pioneered by DKM Software. It pits you against another player where you both attempt to solve the same puzzle simultaneously. As you enter a number in a cell, it appears in your opponent's grid. Once the puzzle is solved, the winner is determined by the player who scores the most points. Points are lost for incorrect entries and there are also bonus points on offer.
The same rules as Sudoku apply - each row, column and block must contain the digits "1" to "9".
Play against your friends (requires Bluetooth connectivity).
Choose from six computer opponents to challenge all skill levels.
An unlimited supply of carefully crafted puzzles – play as often as you like.
Customize the play area with your own colors.
Same proven user interface as found in Pocket Sudoku.
Windows Mobile 2003
Sudoku Sniper uses the Compact .NET Framework from Microsoft that comes standard with all recent PocketPC devices. If you are using an earlier device and get a Compact .NET error when you try and install Sudoku Sniper, you can download the necessary software from Microsoft
http://rapidshare.com/files/226591062/DKM_Sudoku_Sniper.v1.0_PPC.rar
