DioNote 1.0 Crack
DioNote is the software program that allows the
handwritten memos conveniently and quickly.
DioNote is the software program that allows the handwritten memos quickly
and conveniently for the Pocket PC. DioNote provides the alarm function,
and the memo can be transmitted through the IR communication or e-mail.
In addition, the built-in graphics tool, DioNote PHOTO, enables easy
modification of the various images, as well as adding the emoticon or the
clip arts. The images created by DioNote PHOTO can be saved as image
files (*.bmp, *.jpg etc) and can be used as the Today screen for the PDA
Requirements
· WM2003SE/WM5/WM6
· 1 MB of Available RAM
Requirements
· WM2003SE/WM5/WM6
