Cyberlink Power2Go Deluxev600Build3108 new 27/10
    [UPDATES] Cyberlink Power2Go Deluxev600Build3108 new 27/10
    Cyberlink Power2Go Deluxe v6.00.1314 | 10.0 Mb
    "The All-Media Disc Burning Software"
    BS Editor: Burn data onto Blu-ray Discs and HD DVDs
    Create video and photo DVDs, burn audio CDs, and rip MP3s
    Search and locate files instantly using file names or tags
    Secure discs with encryption and password protection
    Drag-and-drop files to burn via the Power2Go sidebar gadget
    Drag-and-Drop burning
    Windows Sidebar Gadget — drag-and-drop then burn files directly via the Windows Sidebar.
    MP3 ripping and audio file conversion — take your favorite CDs and quickly create files for playback on a music player or your home media center PC.
    New-look interface — feel right at home with the new look of Windows Vista; easier navigation and a cleaner design.
    Burn any disc, any file
    Data burning — burn a huge amount of data to disc, on CDs, DVDs, Blu-ray Discs and HD DVDs.
    Video and photo disc authoring — create discs of videos and photo slideshows that play on a home DVD Player.
    Creation of Audio CDs — create compilation CDs.
    Mixed media CDs — burn data files and audio files onto the same disc, play your music on your CD player, then access data on your PC.
    Search and burn
    Simplified burning process — find files in an instant, search using tags or titles.
    Drag to burn — drag complete folders or individual files in one easy step.
    Disc capacity bar — manage the number of files you can burn for your current disc media using the easy-to-read capacity bar.
    Burner settings — take control of the burning process with speed, data settings, auto-run, and other burning options.
    Safeguard your data
    Secured data disc —add a password and encrypt to ensure better protection.
    Disc copying — create perfect duplicates of your discs.
    Erase disc and Disc Image utilities — save or burn disc images, erase and re-use re-writable discs.
    http://depositfiles.com/en/files/dnhi0t02u
    ADMINISTRATOR@SPJ HIT THANKS ON THE WAY OUT
  • broSki
    Old Timer/Snr Member
    • Feb 12
    • 1562
    • Sprint Pro
    • 2963 DL speed REV A
    Re Portable Cyberlink Power2Go Deluxe v6001314
    hey can someone get me another version of power2go, this one isnt working for me on W7, says missing DLL's....
    NOOB SECTION CLICK HERE
    LEARN HOW TO SEARCH CLICK HERE
    LEARN HOW TO FLASH ROMS CLICK HERE
    Sprint Speed:
      Re Re Portable Cyberlink Power2Go Deluxe v6001314
      he bro il check and update thread EDIT i have try a few builds even trial from there site but still gives error not w7 supported i geuss
      ADMINISTRATOR@SPJ
