AlarmPal v1.30 Build 32
Requirements: WM 5.0 and WM 6.0 Touchscreen devices ONLY
Overview: alarmPal is a simple "small footprint" tool designed to provide repeating alarms for all important events. It can be added to tray, title-bar or run in hidden mode. alarmNotes are also available to quickly write a short note or voice message to be reminded of later.In addition a list of the last 10 callers is available to quickly dial your frequent contacts.
AlarmPal Key Features:
Customisable repeating alarms for Email, SMS, MMS, Voicemail, Missed Calls and Reminders
Application runs from tray, title-bar or hidden
Support for 3rd party products including Flexmail, Xpress Mail and Emoze
WAV, MP3, WMA and MIDI alarms (Midi not supported for Treo 700wx)
Create alarmNotes for simple handwritten alarms or voice messages
Quick-Dial option with list of last 10 telephone contacts
Task Switcher to access / close any running application
Supports VGA / Landscape and square screens
English, German, French and Russian user interface
Simple installation
Update - Last updated on 29.04.09
# Improved small errors
serial 12795
