Titanium-Touchflo2 toggler
  • jnuts5423
    Member
    • Sep 07
    • 72
    • touch pro
    its a toggle switch for titanium to TF3D2. I been searchin for 3 days for an easier way than togging to settings and such. There was a program already out for TF 1, but i cooked this little setup with the help of tech at ppcgeeks. Itake no credit for the apps, but they came from multiple sights. Point is, is it works.
    Attatched is second today, tfdetatcher, and the part I looked forever for, the tf3d2detatcher wm6.5cab. Ive played with it every way possible. You need all three for it to work. it maps it to your soft keys. You can set it up however you like.
    Shut off your windows default and your touchflo in settings>today>items. Install in the order they are shown. soft rest and turn windows default back on. and shazam. Toggle back and forth fromTouchflow and titanium in 2 seconds. Best part is, i also map Long send key to be spbmobileshell3 start up. prettysweet.
    Enjoy!
    UPDATE 8-20***
    [/b]after discovering it doesnt work on all roms with the setup above, I found a different way to toggle. It actually closes touchflo as appose to hiding it. saves memory. I found the manilla toggler over at xda.
    HTML Code:
    http://forum.xda-developers.com/showthread.php?t=536019
    however his setup posted did not work for me. I tried many times. but if you combine the TH_manilla cab with detatcher cab, it works. you can map it hard key buttons with dred sensor.
    install TH_manilla toggler cab, the detatcher cab, and the dred sensor cab, then soft reset. I map the show touchflo in detatcher, to the home key using dredsensor. You'll have to go in and edit the default file in dredsensor. put it on hard key simulator, Im sure you guys will figure it out from there. I map the manilla toggler to the arrow hard key. You need both toggler and detatcher, cause neither one will do the opposite. Toggler closes, and detatcher launches touchflo. you could always map the right soft key inside manilla using detacher soft keys, but I maintain the soft keys for second today and whatever else you want. theres a lot of ways to map it, hold send key, etc.. the point is the toggler fixes the problem of touchflo not closing. Im leaving the above settup posted, cause it does work on some roms, and hides touchflo instead of closing it, making it faster, But this is my setup and it works beautifully. If I get good feedback, Ill remove the first posted setup. I look forward to hearing if anyone has a better way to do this, but this is what worked for me. Enjoy!
    PLEASE GIVE THANKS IF YOU ENJOY![
    watch video
    [IMG]https://www.smartphonejunkie.org/gfx_v3-BlackRed/attach/rar.gif[/IMG]     [URL="https://www.smartphonejunkie.org/attachment.php?attachmentid=22428&d=1241463402"]toggle_video.rar[/URL] (4.66 MB, 0 views)
    ORIGINAL THREAD
    http://forum.xda-developers.com/showthread.php?t=480475&page=30
  • jnuts5423
    Member
    • Sep 07
    • 72
    • touch pro
    Re: Titanium-Touchflo2 toggler
    Cant figure out how to edit the first post, but heres a link to the post i mainly got it from.
    I am still a noob and all, so i expect some speptics. LOL
      Originally posted by jnuts5423
      cant figure out how to edit the first post, but heres a link to the post i mainly got it from.
      i am still a noob and all, so i expect some speptics. Lol
      hi wil ad this link to the first posted oke
      moderator@spj
      • jnuts5423
        Member
        • Sep 07
        • 72
        • touch pro
        and here is a video to view of it working on my phone.
        Im using jing, which im starting to think is outdated. It takes up 5 mb's for a minute and 1/2 video. its in shockwave format. did a search for "uploading videos and pics" i got image shack, jing, and mymobiler. so this is what im workin with. Could someone attatch to first post as well. Thank you.
        • wentzeric
          • Apr 22
          • 163
          • Touch & Touch Pro
          • Alltel on Verizon
          I have yet to use this, but tfdetacher is great. I use it to toggle between tf3d and PointUI.....map to a softkey and the other to a long press hardkey and boom....you have double interfaces..mix and match the app you want and you are styling.
          • PHE-NOM
            Creativity Unleashed
            • Oct 14
            • 1494
            • htc pro2 baby!!!!!!
            added your video to first post.
            NEW TO SPJ? CLICK HERE
            NEED TO LEARN HOW TO FLASH? CLICK HERE
            QUIERES SABER COMO DESBLOQUEAR Y FLASHAR TU TELEFONO? PRESIONA AQUI
            TIENES PREGUNTAS SOBRE APPLICACIONES O TEMAS, PERO NO SABES HABLAR INGLES? PRESIONA AQUI
            • shortyboy1987
              Daniel B
              • Jan 30
              • 35
              • htc touch diamond
              i did what u said to do when i installed it when i pressed the soft key it gave me this mess. the file TFDHideTF cannot be opened. either it is not signed with a trusted certifate, or one of its components cannot be found. if the problem persists, try reinstallin or restorin this file. what i do. i reinstalled it 2 n i did nothin samething
              • PHE-NOM
                • Oct 14
                • 1494
                are you running a custom rom? if not you might need NETCF 3.0, or 3.5
                • shortyboy1987
                  Daniel B
                  • Jan 30
                  • 35
                  • htc touch diamond
                  yes i am im runnin bear bonz wm 6.5
                  • PHE-NOM
                    • Oct 14
                    • 1494
                    okay, and you are installing the last one right? the 6.5 cab? because im not sure why you are getting that error, unless you are installing the wrong cab....
                    • shortyboy1987
                      Daniel B
                      • Jan 30
                      • 35
                      • htc touch diamond
                      #11
                      yup i installed everythin do u want me 2 install it 2 the device that make a dif
                      • mispook08
                        • 3014
                        • HTC Vogue (Sprint Touch)
                        #12
                        Yea bro install this to your device ,i tried it on the card and for some reason didnt work until i install in the device
                        • shortyboy1987
                          Daniel B
                          • Jan 30
                          • 35
                          • htc touch diamond
                          #13
                          k thanks man it works good
                          • mispook08
                            • 3014
                            #14
                            Great bro glad u got it work yea thinks like this u should install in device ,use storage card for music ,pics i do install cabs in storage but only if its neccesary .
                            • shortyboy1987
                              Daniel B
                              • Jan 30
                              • 35
                              • htc touch diamond
                              #15
                              ight thanks for the info
