ActiveKitten Chronos v462 01/11/2010
  • Bigrob
    • 1107
    • Touch Pro
    [UPDATES] ActiveKitten Chronos v462 01/11/2010
    ActiveKitten Chronos v4.0
    Requirements: Any Pocket PC WM2003-WM2006 with ARM/Xscale processor
    Overview: Chronos fills a gap in PocketPC operating systems by offering an unlimited number of alarms and timers with customizable sound (MP3, WMA and OGG) and time settings. Two countdowns with lap times lets you track time spent on certain tasks. Supports VGA, square screens and landscape orientation.
    1. Unlimited number of highly customizable alarms:
    * Alarms can be set to signal only on certain days of the week;
    * alarms can be one-time or repetitive;
    * alarm can notify you by playing sounds, turning on/off vibration, blinking the LED;
    * WAV, OGG, WMA and MP3 alarm files are completely supported as sound notification;
    * you can select custom sound stored in memory or on the storage card;
    * the sound can be played with ascending volume and in loops (i.e. as many times as you need);
    * vibration (requires hardware availability of the feature) can be set to work before or with the sound. Pulsation is customizable too.
    2. Unlimited number of countdown timers. These timers are used to notify you when certain amount of time elapses. You can completely customize sound and vibro notifications for the timer (in the same way as for alarm). Settings of each countdown timer can be saved as a template for future use. You can build a sequence of timers.
    3. 2 multi-stage timers that let you count time of some action and compare results of two attempts. You can use timer to fix intermediate results (for example when you run 5 laps, you can track time of each lap).
    4. Skinnable clock with screensaver and hourly sound lets you have better control over your time.
    What's new in Chronos for Pocket PC 4.0:
    · A lot of fixes
    · New skins added
    · Time correction via atomic clock feature
    · Redesign of panel selection
    · Snooze support in timers
    · New action "Change device volume/vibration"
    · Added option to run a screensaver at system startup
    http://www.uploadjockey.com/download/1479888/ActiveKitten.Chronos.v4.0.Final.rar
    Mirror:
    http://rapidshare.com/files/222248767/ActiveKitten.Chronos.v4.0.Final.rar
    http://www.megaupload.com/?d=1BWLIAB7
    NEW RELEAS ADDED BY CYBER WEESJE 01/11/2010
    http://www.megaupload.com/?d=XYJG0JF3
  • roopull
    Addict
    • Feb 27
    • 295
    • Touch Pro
    Re: ActiveKitten Chronos v40
    Downloaded & installed.
    I work two jobs, and one of those jobs has varying start times depending on the day of the week. So, the THREE alarms available in WinMo really didn't cut it for me.
    This is simple, easy to use, lots of features w/o being "too much," and did a fine job of waking me up at 2 am, this morning.
    Good app! Thanks for adding it.
    • Bigrob
      • 1107
      • Touch Pro
      I appreciate the review and the feedback. I have some very similar time issues myself. Glad you like it.
      • roopull
        Addict
        • Feb 27
        • 295
        • Touch Pro
        I'm not 100% sure it was the Activekitten program that did it, but I missed work Friday. After several months of the phone running flawlessly, it froze up at 11:53 PM Thursday night. Of course, the alarms didn't go off that I'd scheduled for 2AM.
        The kitty is not on my phone, anymore.
        Prior to this, I've not had a single problem with my Touch Pro. O
          Re ActiveKitten Chronos v462 01/11/2010
          bump bump new releas added
          grtz cyber weesje
          senior admin@spj
