Run GPS Trainer UV Pro 232 Build 1520
    [RELEASE] Run GPS Trainer UV Pro 232 Build 1520
    This verion - > What's new in Run.GPS Trainer UV Pro 2.3.2 Build 1520
    · application may hang when it is closed (if an upload process has been cancelled before)
    Run.GPS Trainer UV Pro 2.3.2:
    · added configurable "lead directly back to route" navigation - leads you directly back to your route only if a configurable distance is exceeded
    · added the Italian language
    · auto-reconnect function for FRWD B100/B600
    · added direct download button for online maps (Main Menu > Configuration > Map Settings > Items on Map)
    · fixed problem of zoom bar getting displayed to small on *some* high resolution devices
    Run.GPS Trainer UV Pro 2.3.1: =V@fYEc@B]
    · vibrate the device when user is off route, current interval is switched, heart rate/speed limits are exceeded or GPS signal is weak- add a new map layer showing nearby users (or optionally only live users or only friends
    · provide direct access to the redacted tours on Outdooractive.com (Main Menu > Online Services > Find Routes) (mostly for Germany
    · automatically switch on backlight when getting close to a turn or when a placemark information window pops up
    · make it possible to stop/cancel any uploading or downloading process ?S[Y&FTF
    · added Russian, Czech, Hebrew and Dutch translations
    · added new sports cross-country-skiing, mushing, sledding and snowshoeing
    · provide an interface to use the Live Tracking feature with crossingways.com Bi
    · restructure the "Map Items" dialog in a more logical way
    · make buttons '1' and '2' switch to the next/previous screen instead of switching to 'Recorder' and 'Map' 62
    · support for Windows CE (requires a CE device with .NET Compact Framework installed and support for alpha blending (i.e. transparency
    · restore last used zoom level when application is started
    · provide extra setting to keep the backlight turned on (Main Menu > Configuration > General Settings > Keep backlight always turned on; this setting is useful for owners of Smartphones without touchscreen who cannot handle the button on the main screen)
    · trainingplan activities: translate sports
    · package all languages in one installation file (DE, EN, FR, ES with voice output, CZ, RU, HE, NL without
    Run.GPS Trainer UV Pro 2.3.0 build 1376
    · better map zooming for Smartphones (without touch screen
    Run.GPS Trainer UV Pro 2.3.0 build 1374
    · fixed a bug which may result in application crash (when trying to open reports in an unsupported web browser; when removing info popups on a map while a new info popup is opened
    · improved calculation of ascent and descent
    QziCVbxG'
    Run.GPS Trainer UV Pro 2.3.0:
    · support for Bluetooth heart rate monitors `
    · optional dialog for selecting sport when application is started (Main Menu > Configuration > General Settings > When application is started > Select Sport\
    · make it possible to upload indoor activities (recording only heart rate and cadence, but no distances and speeds, without GPS connected)
    · integration of additional sensor data: heart rate, cadence, temperature, air pressure
    · new diagrams: heart rate diagram, pace diagram, cadence diagram, temperature diagram, DOP diagram .
    · show info popups directly on map when getting close to a placemark or when clicking on a placemark
    · add zoom slider to maps
    · add Bluetooth drivers for Zephyr HRM/HxM and FRWD B100 devices
    · add master switch for interval training
    · interval training: make it possible to select interval length in 10 seconds increments
    · do NOT store speaker volume and do NOT set it to the stored value when application starts (just keep the current volume setting on the device from now on - volume can be changed in Main Menu > Voice Output)
    · make cursor better visible for high resolutions
    · add "reverse route" to dialog "select for navigation or delete"
    · diagrams: add horizontal bars for average value (speed, pace, cadence, heart rate, temperature) and interval min/max limits (speed, pace, heart rate
    · add ability to completely lock hardware keys (if you use this function, you cannot at the same time use the center key for starting/stopping the training session; on a Touch HD this locks all keys except the Power key and the Home key
    · add remote control for MortPlayer (start/pause/frwd/back)
    · scale all icons on map on high resolution devices
    · bug fixed: when switching from Navigator to Map screen, map tiles are often displaced
    · uploading of placemarks from Run.GPS to GPS-Sport.net portal website `
    · when user starts a training session from a planned activity, set min and max heart rate for the new training from the planned activity
    · add color pink for tracks and routes
    · many improvements for high resolution devices
    · bug fixed: training log does not show correct max heart rates for planned activities
    pw no password
  • Longfist
    • Apr 04
    • 292
    • several
    • quakor
    Re: Run GPS Trainer UV Pro 232 Build 1520
    Great i ll test it asap.
    Now with my new mobile its possible again.
    whahahhahhaha u dont know how happy i am when i am back in controle of a HTC
    grtz
    --------- New Post Merged on 5/5/2009 at 1020 --------
    grtz
    i cant seem to unrar the file,says crypted with password
    • forty01
      Supporter
      • Nov 24
      • 1169
      • HTC Touch Pro/HERO
      grtz
      "no password" is the password ;)
      About the "I Win" Champion Click Here
      Flashing a ROM Click Here
      Noob Zone Click Here
      How to Search for...? Click Here
      • Longfist
        • Apr 04
        • 292
        • several
        • quakor
        Yes thnx m8 didnt see that.
        Sometimes i am to rushy
        grtz
        • forty01
          Supporter
          • Nov 24
          • 1169
          grtz
          Not a problem, that's what we're all here for :)
