Token2Shell/Mobile v510
    [RELEASE] Token2Shell/Mobile v510
    Token2Shell/Mobile v5.1.0
    Requirements: WM5.0, WM6.x (Standard/Classic/Professional)
    Overview: You can now have Token2Shell/Mobile, a rock-solid SSH client for Windows Mobile. So, stop playing games on your phone and let's have some work done!
    • Comprehensive SSH Support
    Token2Shell/Mobile supports all the widely used algorithms and methods for SSH connections. Once Token2Shell/Mobile is installed, simply enter your server address and tap Connect! Along with robust SSH features, Token2Shell/Mobile also supports TELNET, TCP Direct, Serial(COM) Port and Modem(Phone) connections.
    • Token2Shell.SSHpf/Mobile
    Token2Shell/Mobile includes a dedicated standalone application called "Token2Shell.SSHpf/Mobile" for SSH tunneling. Token2Shell.SSHpf/Mobile runs transparently in the background and provides tunneling or port forwarding for other applications.
    • Designed for Mobile Environment
    Keybar, SmartClick, Built-in Bitmap Fonts, Virtual Screen Size with Drag-and Scroll, Property Scroll
    • Seamless Feature Integration
    Address Book, Login Agent, SSH2 File Browser
    • Convenient Built-In Tools
    Command Macro, Textbar, Hardware Button Assignments, Full Screen Mode, PING and TRACE-ROUTE
    • Desktop Ready!
