Overview
From the creator of TouchFlo Detacher comes Mobile Shell 3 Toggler! This is a sister app (at least in spirit) to TFD.
MS3T allows you to quickly and easily switch between the classic Today screen and SPB Mobile Shell 3 by using shortcuts which can be assigned to hardware buttons, links in MS3 itself, etc.
Tip Jar
Like this app? Want more like it or quicker updates? Tip a buck (or Euro or Pound or whatever) or two to help the author out! Click here to make a safe donation via PayPal.
Current features
MS3T adds the following links into the Mobile Shell folder in your Programs folder.
[Close Spb Mobile Shell] - Kill the MobileShell.exe process
[Hide Spb Mobile Shell] - Show the classic Today screen
[Show Spb Mobile Shell] - Show Mobile Shell 3
[Toggle Spb Mobile Shell] - Show Today if MS3 is visible; Show MS3 if Today is visible
[SmartToggle Spb Mobile Shell] - Similar to Toggle, but it will only toggle if you are already on the Now or Today screen. If you are in another app, it returns to the Now or Today screen. That's what makes it smart. :-)
Limitations
If you try to assign SmartToggle to the HTC Home button (using AE Button Plus, for example) on your HTC device, it will only work as a regular Toggle. The reason is that the home button always returns to the Today screen (or Now screen) BEFORE AE is able to tell SmartToggle to run. So, SmartToggle sees that you are currently on the Today screen and will toggle accordingly. The same problem will probably also exist with any other similar type of button on other manufacturer's devices.
History
V1 - Initial release
Download
Attached to this post!
Requirements
Windows Mobile 6.1
Spb Mobile Shell 3
