050609-dB_ROM WM 65 215012150221222 ROM/Kitchen TouchPro [Multi-ROMs
  • Megzy
    • Aug 20
    • 1044
    • htc 63cc
    • BT
    [NEW] 050609-dB_ROM WM 65 215012150221222 ROM/Kitchen TouchPro [Multi-ROMs
    This is a port of the excellent Da_G Fuze (GSM) Kitchen. It has been fully modified to work on all CDMA Touch Pro's. I personally have a Sprint Touch Pro.
    Da_G has been gracious enough to consider this the "CDMA Version" of his very popular kitchen. Without his help over the past two weeks, I would have never been able to get the new Bepe (Ervius) style kitchen working. I also received a lot of initial help from MightyMike. His kitchens and personal OEMs are what got me started. So, here are the usual "thank you's":
    Da_G (XDA), MightyMike, Bepe (XDA), Ervius (XDA), Dan-HTC-Touch, Tsowen (XDA), Showaco (XDA), TPlane37 (XDA), Calkulin (XDA)
    If I have forgotten to mention you in the above list, don't worry, I didn't forget about you. (Wait, yes I did.) But, please send me a message so I can add you to the list!
    This IS NOT my first relase of this kitchen/ROM. This is simply my first release of it on PPCGeeks. You can check the history of dB_ROM at my XDA Thread. Read through the posts there, you will see it's one of the best around. I finally posted this here because the GSM Raphael rules XDA. I was the first to launch a CDMA Kitchen for it there. That shows you how few people actually talk about the CDMA TP there. So, I would like to maintain both threads. Please help me in doing so. Thanks!
    Information on where the Kitchen was built from:
    SYS: Da_G
    XIP: Da_G
    OEMs: MightyMike, Da_G, Tsowen (Taskbar), Showaco (Titanium Weather), Me
    EXTs: Same as OEMs list
    Kitchen Design: Da_G modification of Ervius' base kitchen based on Bepe's new style kitchen (PlatformBuilder)
    CHANGELOG:
    Wednesday (5-6-2009)
    Updated SYS to 21222
    Added ATContacts
    Added CHome Editor
    Updated Titanium Weather to 4.2
    Updated Mortscript to 4.3b5
    Added Option for 4 Column Start Menu in Kitchen (Included in ROMs)
    Minor Registry Tweaks
    Monday (4-5-2009)
    Updated SYS to 21502
    Updated to Ervius 7.6
    Changed Organization of EXT Folder per this update
    Fixed multiple build errors that were being suppressed
    More accurately diagnosed and corrected "Corrupted Ringtone" errors
    This should fix the silencing of sounds/notifies randomly
    Were some memory overlaps in a key module
    Fixed Teeter
    Minor Registry Tweaks here and there
    Added many different "pre-built" roms.
    Each of these have a ".erv" file. Look in "Load ROM"
    Look below the screenshots for the Comparison Table
    Monday (5-11-2009)
    Updated AdobeFlashLite
    Updated RemoteDesktop
    Updated Widgets
    Updated Windows Update
    Titanium Pictures tab open HTC Album by default (if Album installed)
    Added Notification Enhancement (Rhodium/Topaz)
    Added Custom Round Icons for NE
    Added New Round Taskbar Icons
    Added PowerOff Warning to match NE
    Added White NonS2A Dialpad Skin to Kitchen (No ROMS built with it)
    Updated GoogleMaps to 3.0.1.6
    Updated HTC Zip to 1.21.18193225.0
    Added G-Alarm 1.5.1
    Added SmartLock 1.7C by Chobit Company
    Resolved XIP Issue for VZW TouchPro's
    Dropped SPRINT FULL from Pre-built ROMs
    Dropped ALL CDMA Carriers Basic from Pre-built ROMs
    Added SprintTV and Sprint NAV to CABs (Still in Kitchen)
    Added ATContacts
    Added CHome Editor
    Monday (4-5-2009)
    Fixed Teeter
    Stable enough for every day use? Well, I am (Yes, I stole this from Da_G, BUT, I REALLY AM USING IT DAILY!)
    Instructions for new style kitchen (build 21501 and above)
    Step 1. Extract to a clean folder
    Step 2. Run erviuskitchen.exe
    Step 3. Click "load rom"
    Step 4. Choose "dB_ROM-21501"
    Step 5. Scroll down to section labelled "HERMAN-Device: HERMAN_External_Packages" in blue text
    Step 6. Double click packages here to enable or disable them (first column reads True for enabled, False for disabled) (Leave alone for Defaults)
    Step 7. Do the same for section under that labelled "SHARED-Devices: WindowsPhone_Components" as step 6 (Leave alone for Defaults)
    Step 8. (Optional) Click "Save ROM" and choose a filename, to save your package choices for loading in the future
    Step 9. Click "Create ROM"
    Step 10. ROM is available in .nbh form in kitchen folder \HERMAN_RELEASE, you can either flash it with the included RUU.exe or rename to RAPHIMG.NBH and place on fat32 formatted SD card, for SD flash
    General Notes for ROM and Kitchen
    Always hard reset after initial flash. (I always wait till Autorun/SDAutorun complete and device soft resets)
    Soft reset after hard reset doesn't hurt anything. (Comes from my old Titan days)
    Don't worry about all the "Overwriting..." in the kitchen build process. It's normal and expected.
    DO NOT use XIP 21502 in Kitchen. It's broken. I know what it is, but there is no change from the 21501 XIP, so just use it.
    Report all bugs, etc here. Da_G and I have worked hard to make this as bug free as possible, but, Stuff happens.
    If you are run Windows Vista or 7 and use the Kitchen, you must Right-Click ErviusKitchen.exe and select "Run as Administrator..."
    Don't blame me if you brick your device. It's not my, or the kitchens, fault. You recognize the potential problems that can arise from flashing your own ROMs on your phone. Da_G and I will take no responsibility. "Use at your own risk."
    All that being said, I have had no issues during flash processes. I use this as my daily phone and have no ill side effects.
    Before you Begin
    If you have never flashed a ROM before, PLEASE read the information posted by jakdillard in the sticky thread of this forum. You must first unlock your SPL and learn how to flash. All the information on doing this has been gathered and placed in a easy to follow step-by-step guide in the thread. Here is the direct link.
    Download Links
    21222 VGA WWE ROM - Full - Sprint Optimized - Beta 1
    21222 VGA WWE ROM - Full - ALL CDMA Carriers - Beta 1
    21222 VGA WWE ROM - No Manila - ALL CDMA Carriers - Beta 1
    21222 VGA WWE ROM - Basic - ALL CDMA Carriers - Beta 1
    21222 VGA WWE ROM - BareBones - ALL CDMA Carriers - Beta 1
    21222 VGA WWE Kitchen for Touch Pro (CDMA) - Beta 1
    21502 VGA WWE ROM - Full - Sprint Optimized - Beta 1
    21502 VGA WWE ROM - Full - ALL CDMA Carriers - Beta 1
    21502 VGA WWE ROM - No Manila - ALL CDMA Carriers - Beta 1
    21502 VGA WWE ROM - Basic - All CDMA Carriers - Beta 1
    21502 VGA WWE ROM - BareBones - ALL CDMA Carriers - Beta 1
    21502 VGA WWE Kitchen for Touch Pro (CDMA) - Beta 1
    21501 VGA WWE ROM for Sprint TP - Beta 1
    21501 VGA WWE Kitchen for Touch Pro (CDMA) - Beta 1
    NEW 11/05/09
    http://rapidshare.com/files/231819913/dB_ROM-wm6.5_21222-Full-ALL_CDMA_Carriers-v2.rar
    Thanks to decibel and Da G for all the hard work... original thread found here:
    http://forum.ppcgeeks.com/showthread.php?t=67426
  • Megzy
    • Aug 20
    • 1044
    • htc 63cc
    • BT
    Re: 050609-dB_ROM WM 65 215012150221222 ROM/Kitchen TouchPro [Multi-ROMs
    Known Issues:
    21501
    Teeter not installing properly. (FIXED - CAB ATTACHED)
    Alarm Sound not working (Appears in ALL CDMA 6.5 ROMS)
    Sounds & Notifications getting "Ringtone is Corrupt" randomly. (Semi-Fixed in 21502 release)
    Default "CallerID Bubble" showing up with S2A, S2A wins battle.
    21502
    Sounds & Notifications getting "Ringtone is Corrupt randomly. Post Regarding Status (Testing Fixes... STILL)
    21222
    Fixes:
    21501
    Teeter not installing EXE or MUI file - RS DOWNLOAD - CAB ATTACHED 29.04.09
    21502
    Borked the "RomSaved" folder in the kitchen. If you downloaded the Kitchen prior to 02:02 CST on May 4, 2009 (Or you look in <TOOLS\RomSaved> and you only have one .erv file), you need to download the <RomSaved.zip> file below. Extract the contents to your <TOOLS\RomSaved> dir.
    Extras:
    Attached ATContacts in cab form, per request. Included in Kitchen/ROMs now.
    • Megzy
      • Aug 20
      • 1044
      • htc 63cc
      • BT
      How To Create EXT Packages for New Style Kitchen:
      Download the EXT_Package_Tools.zip below and extract the two exe files inside to the <TOOLS> folder of the Kitchen.
      If you have a cab, run Cab2OEM.exe on it first. Otherwise, goto step 3.
      Run EXT_Packages_Rebuilder.exe on the OEM Package directory.
      Place the resulting folder in the <EXT\Herman\Common\*> Directory it belongs in.
      Example:
      Open two explorer windows. Have one window open to the <TOOLS> directory of the Kitchen. Have the other window opened to the directory containing your CAB or Original OEM Package.
      Now, if its a CAB, drag the CAB file and drop it on top of Cab2OEM.exe. This will open a command prompt and close it. You should now have a folder in the Explorer window containing the CAB file.
      Make sure the folder contains all the files, including the *.rgu file, etc. Now Take that entire folder and drop it on top of EXT_Packages_Builder.exe (Drag the Folder, not the files inside, but the ROOT folder). This should restructure the Folder created in step 2 to have a <files> folder inside of it that contains all the files for the Package, including any .provxmls. There will also be an <app.dat> and <app.reg> file (if applicable). The <app.dat> is the old "initflashfiles.txt". The <app.reg> is the old "*.rgu".
      Now check the reg file and make sure it looks setup properly. Cab2OEM.exe likes to bork registry files sometimes. So I would look over this carefully. After you're sure its good, move the folder to the appropriate area in <EXT\Herman\COMMON>. Load up your fav ROM pref from my Kitchen. Scroll down to your package and make sure its "TRUE". Cook and be done.
      EXT Package Folder Structure:
      <Root Folder> - Name of Package
      --<files> - Folder that contains all files that will be installed to \Windows
      --<app.dat> - The old <initflashfiles.dat>, contains instructions to copy files, etc.
      --<app.reg> - Contains all registry entries for the Package.
      • 2LoWw7
        • 110
        • Touch Pro
        Ringers corruption fixed in this sys update??
        • Megzy
          • Aug 20
          • 1044
          • htc 63cc
          • BT
          I believe it is for the latest 21222 build...its still there in the 21502, not sure about the 21501... some say they haven othere say they have randomly
          • Megzy
            • Aug 20
            • 1044
            • htc 63cc
            • BT
            ^^^bump bump^^^
            post # 3 updated w/ new kitchen info and attachments!
            • BucksFloBx
              It just business...
              • May 11
              • 121
              • Touch Pro 2 / Unlock
              FYI : I have test this rom and it is running smooth
              CHANGELOG:
              Monday (5-11-2009)
              Updated Widgets
              Added G-Alarm 1.5.1
              Added ATContacts
              Added CHome Editor
              Monday (4-5-2009)
              Fixed Teeter
              i930 / Moto Q / PPC-6800 / Touc Pro ( 5 replacements ) / Touch Pro 2
                Originally posted by BucksFloBx
                I have post the Update [ 05 11 09 ] at this link
                But it was close.
                CHANGELOG:
                Monday (5-11-2009)
                Updated Widgets
                Added G-Alarm 1.5.1
                Added ATContacts
                Added CHome Editor
                Monday (4-5-2009)
                Fixed Teeter
                hi wil update to the above posted bud your thread is closed and binned so the link will be removed PS CHECK MY SIG HOW TO CODE A LINK SINCE YOU [QUOTE] IT OKE
                MODERATOR@SPJ
                • BucksFloBx
                  It just business...
                  • May 11
                  • 121
                  [QUOTE=weesje;368457]hi wil update to the above posted bud your thread is closed and binned so the link will be removed PS CHECK MY SIG HOW TO CODE A LINK SINCE YOU
                  IT OKE
                  MODERATOR@SPJ
                  Thanks for the information. Just trying to help out to drop the new Beta 2. Thanks anyways
