iTouch Ultimate touch sensitivity
    [RELEASE] iTouch Ultimate touch sensitivity
    ThIS WILL INCREASE THE SENSITIVITY OF YOUR PHONE......that is ....... IT WILL RESPONSE WITH JUST A TOUCH NOT A PUSH
    the tweaks are as follow!!
    FINAL VERSION RELEASED iTouch_azharsunny.cab ( SET TO MAX VALUES )
    iTouch_azharsunny.cab FOR ALL DEVICES MADE AFTER DIAMOND INCLUDING DIAMOND( TP, HD, 3G....and so on! )
    HKLM/Drivers/TouchPanel
    PressureThreshold = FFFFFFFF in HEX
    HKLM/Software/OEM/TFLOSettings
    FingerPressure FFFFFFFF in HEX
    touchresponse_azharsunny_enchanced sensitivity.cab HAS THESE VALUES )
    PressureThreshold = 80866 in decimal not HEX
    FingerPressure 80866 also in decimal!!!
    try them out and let me know!!
    Works ONLY ON HD, DIAMOND, FUZE, RAPHAEL, 3G, VIVA, CRUISE, XPERIA1, GENE, JADE, Trinity!!! try it on your devices to find out if it works for u and let me know so i can update!!
    NOW FEATURING in the BEST ROM FOR DIAMOND(its best in my eys only btw as its exactly what i need) link for rom is as follow
    http://forum.xda-developers.com/showthread.php?t=469852
    THIS WILL HAVE NO EFFECT ON BATTERY!!
    FOR MAX SENSITIVITY USE FINAL VERSION iTouch_azharsunny.cab ( THIS HAS MAX VALUES SET TO FFFFFFFF IN HEX FOR BOTH TWEAKS
    FOR Medium sensitivity USE ( enhances TF3d and evrything else!!)touchresponse_azharsunny_enchanced sensitivity.cab
    OLD CAB touchresponse_azharsunny.cab ( only enhances TF3D
    For DEFAULT jus perform a SCREEN ALIGNMENT
    http://forum.xda-developers.com/showthread.php?t=469865
  • TaylorSPJ
    Nickel Nickel NINE
    • Oct 17
    • 1243
    • HTC DIAMOND
    Re: iTouch Ultimate touch sensitivity
    hey weesje i have cabs with these same settings on my tweaks thread I've had them on there for months now....so if u want u can toss it in the bin, or leave it ....ur choice
    New to the site click here
    Need to learn to flash Rom's click here
    For all my Hacks, Cabs and Tweaks click here
    AND IF SOMEONE HAS HELPED YOU HIT DA THANKS BUTTON!!!
