Advanced Network Caller ID Updated v5 with StandAlone GUI
    [RELEASE] Advanced Network Caller ID Updated v5 with StandAlone GUI
    an enhanced Caller ID. On incoming SMS or phone calls a window pops up that displays,
    - The full name of caller
    - Address of caller with a map link
    - The number of FTC and caller complaints (to tell if it’s a spam call)
    - Telco name and location (can tell what carrier the call is from) d_
    - Relatives of caller (with age!) Do)
    - Criminal History
    I've also added the ability to add the caller to the contacts book, return the call, and look at past calls. A standalone GUI to run alone and lookup past calls can also be used.
    I've only tested and ran this on the HTC Touch Pro and it works well, even for unknown cellular calls. It's kind of crazy the information you can get.
    Looking for suggestions, changes, additions - definitely let me know and I will happily (and quickly) add them. You can reach me at kwatkins@gmail.com
    Release Notes
    - NetCallerID waits until the call is answered or finished before doing the network calls. For the most part, the network connection is unavailable until the phone call is ended.
    - If roaming is enabled NetCallerID waits until your out of roaming.
    - All history of calls are in the program files\netcallerid\calllogs directory in html format. You can view these with Opera or Pocket IE.
    - The setup automatically starts the program. I also put it in \Windows\Startup to start when you re-start the phone.
    Download:
    http://www.kwatts.net/netcallerid/netcallerid.cab
    http://www.kwatts.net/netcallerid/netcallerid.msi
    Instructions:
    Just download the cab and run it on the device. It will automatically start and also start on reset. For the msi, install it on the PC, it will be added to your phone when you connect it to the PC. Go under programs and click the netcallerid icon to run the standalone GUI.
    This is very alpha. Pre alpha even. I'm not liable for anything, run at your own risk, etc etc
    Prerequisites
    -WM5 or 6/6.1 with CF 3.5
    Changes for v .3 U
    - Added logic to the add to contacts where if name is in address book prompt/don't add.
    - A full standalone app has been added where you can lookup past calls. SfbjP#C^
    - Added the program to the programs list.
    - Numerous bug fixes
    - SMS is now turned off by default. Some people were getting Very.Bad results where SMS messages were being swallowed. I *think* it should be fixed but unsure, it's something in the SMS .net interception library. If you really want SMS turn it on under config, do a soft reset, and if you see your not getting SMS messages immed. uninstall and let me know!
    - added whitepages.com lookups
    Prerequisites
    Changes for v .4
    - UI changes to work on all WM phones and resolutions (including QVGA 320x320)
    Changes for v .3
    Changes for v .2
    - Fixed install to storage device errors
    - Fixed the configuration GUI
    - Added MSI installer
    Changes for v .5
    - extended API.
    - updated GUI
    - better support for all wm platforms
    - numerous bug fixes
    MODERATOR@SPJ HIT THANKS ON THE WAY
  • bxr84257
    • 10
    • HTC Diamond
    Re: Advanced Network Caller ID Updated v4 with StandAlone GUI
    I tried to install this but I got an error message saying "this application requires a newer version of the Microsoft .NET compact framework than the version installed on this device." I installed the msi to my PC, but i never saw it being added into my phone?? and by the way what is msi lol?? THANKS!!
    • MikeyD
      Find Em Hot Leave Em Wet
      • Apr 25
      • 1609
      • TP2, omnia, Mogul
      • Can You Hear Me Now
      if you had the .net 3.5 framework and your phone activesynced it should have installed on your phone....or just search for the cab to put on your phone i know we have it here.
      Can't Access Something Click Here
      Can't Find Something Click Here
      Need Help, Check Out the Help Desk Click Here
      IF SOMEONE HELPS YOU HIT THE "THANKS" BUTTON
      FOLLOW THE RULES
      AND PLEASE CLICK INSTALL ON ALL APPS AND THEMES
      PLEASE POST SOMETHING, ANYTHING HERE
      • V I P
        previously codydavis22
        • Oct 04
        • 296
        • Motorola Droid
        • Verizon
        I installed and opened the application and clicked on look up and config and they both come up with an error message.
          hi whats the error msg give a bit more info
          MODERATOR@SPJ
          • V I P
            • Oct 04
            • 296
            • Motorola Droid
            • Verizon
            I don't get the error message anymore but the application doesn't seem like it is VGA compatible. You can't see the top of it and it doesn't look like the screen shots.
            • JDMSOHC
              i'LL ReP SPJ 4 dAyZ...!!!
              • Feb 25
              • 60
              • HTC TouCh PrO..!!
              well as stated in the first post, he tested it on his Touch Pro and it worked fine "vga" and I'm using it flawlessly on my Touch Pro "vga" so there must have been an issue with ur install, i'd uninstall and try again... I've had no problems at all..
                Originally posted by jdmsohc
                well as stated in the first post, he tested it on his touch pro and it worked fine "vga" and i'm using it flawlessly on my touch pro "vga" so there must have been an issue with ur install, i'd uninstall and try again... I've had no problems at all..
                thanks for the feedback
                grtz cyber weesje
                moderator@spj
                • V I P
                  • Oct 04
                  • 296
                  • Motorola Droid
                  • Verizon
                  Did you download the cab that is uploaded to the site?
                  • tsunami69
                    Member
                    • Aug 20
                    • 66
                    • htc 6800
                    • Alltel
                    Im also using this on a Sprint Touch Pro and it works fine but the only time I would get an error is when I hit lookup more than once. Other than that it works ok
                    • frenchw82
                      • Mar 13
                      • 19
                      • HTC Mogul
                      #11
                      This program is crazy man, it gives me every blood related family member you know just by the phone number. Scary!
                      • V I P
                        • Oct 04
                        • 296
                        • Motorola Droid
                        • Verizon
                        #12
                        People that are using this on the TP...does the program look like the screen shots? This program does not work very well for me. It is almost unresponsive....ie takes about 20 seconds to respond to a tap and it only works once in a while
                          #13
                          hi if you see the feedback its working for members that installed it dont now what the problems on your device is and give no support on this
                          MODERATOR@SPJ
                          • V I P
                            • Oct 04
                            • 296
                            • Motorola Droid
                            • Verizon
                            #14
                            Here is a new version that I am going to try anyway...
                            http://forum.xda-developers.com/showthread.php?t=494433
                              #15
                              Originally posted by v i p
                              here is a new version that i am going to try anyway...
                              thread update hope this one works for you
                              grtz cyber weesje
                              moderator@spj
