iCaller 0103
  • Bigrob
    • 1107
    • Touch Pro
    [RELEASE] iCaller 0103
    iCaller 0.1.0.3
    Simple CallerID application which extends system default Incoming Call screen with full-sized pictures, additional contact information and fully customized interface.
    Currently, it is an alpha version, which means that it may contain bugs and do not work correctly on some devices. Please give me the feedback, I'll be fixing issues.
    You may get it also at my new home site
    - Lightweight
    - Expands default incoming call screen without affecting its behavior
    - Full-sized contact picture
    - Pictures can be stored on a Storage Card or in Pocket Outlook database
    - Picture can vary for the same contact depending on its phone number (just name the picture with a number, e.g. 5554433.jpg)
    - Customized interface based on HTML (using system HTMLView control, thanks for idea goes to mrproper
    - Screen lock functionality
    - Speed improvements
    - Bugfixing
    Instructions:
    - Unpack contents of the archive in a folder on your device, e.g. \Program Files\iCaller (do not forget to copy zlibce.dll too!)
    - Check settings.ini - it is configured for English version of Windows Mobile OS, you may need to replace sSysCallerWndTitle option from 'Phone - Incoming...' to your localized name of system default Incoming Call window
    - Launch iCaller.exe
    For detailed instructions refer to readme.html
    http://truburt.net/
